Good work on the results you're getting so far!
Originally Posted by SaerinRhoe
There's plenty of times that I forget that I can't {...} squeal around corners {...} and still get 50mpg. ![Stick Out Tongue](https://www.fuelly.com/forums/images/smilies/tongue.gif)
Well, actually...as long as you're coasting, it's more efficient to keep whatever inertia you can than it is to brake before the corner. You'll just need to re-accelerate after the corner anyway.
I've tried different routes but the most effective ones (ie: routes that aren't residential with stop signs every 2 blocks or routes that aren't highway) all have at least 2 school zones that I have to go through.
Have you done the calculations to decide whether it saves fuel to go a shorter route at less MPG vs. a longer route with better MPG?
Currently I run an average tire pressure of 44psi on the factory Bridgestone Potenza P185/60/R15 84T rubber. In the summer I drop the tires to 40psi to account for +105 degree days and lots of driving.
If you're concerned about safety, you should inflate to higher pressure when you expect more heat. Lower pressure generates more heat in the tires. I suspect that even 40psi is well beyond your car's recommended pressure so there's no issue of overheated tires either way.
I would like to remove the rear seat, spare tire, jack and all assorted pieces of hardware for this. Rumor has it that this will remove ≈100lbs of weight from the car and I rarely use the rear seat anyway.
That could possibly help with your auto-X weekends, but I doubt you'll ever get a measurable fuel economy advantage from a mere 100 pound weight loss. Very few cars get a fuel economy difference until you're talking about over 10% weight change.
