I've owned a california (or
I've owned a california (or so I thought) Civic VX before, and it had a 5 wire (wideband) O2. This O2 is what allows the engine to run in the lean burn mode. But like Matt said, the ECU and O2 go together.
As far as removing the CA emmisions, don't bother. If anything you're looking at an EGR system, which is NOT easy to remove. I would just do tune up on it and replace the O2 sensor (even a 30k mile O2 will not yield you the same mileage as a brand new one will). Check first and find out what code its throwing before you do anything though. A broken EGR valve can really mess up your mileage, but my guess is that it's complaining about the O2 sensor or there is a leaky injector.
Anger is a gift!- Zack de la Rocha
