Hi to everyone, from Chevy Aveo Owner - Page 3 - Fuelly Forums
Old 05-16-2006, 04:29 PM   #21
PSI = 50 = good,
PSI = 50 = good,
Old 05-16-2006, 04:36 PM   #22
95metro's Avatar
Re: that's why i'm here
Originally Posted by tvent
I'm here b/c I want to make the mileage better. Seems like people are talking alot about tire pressure. I check mine, and got it at 32psi all around, guess I could put it up to 35 or max? Got to read up on exactly what a hot air intake is and what to try first.
If you're serious about it - and your gaslog seems to prove that - get a ScanGauge before you do anything to the car. That's my personal opinion because any mods done to your vehicle should be tested to death to see if they are any benefit/detriment.
My tires are rated for 35 psi, but I boosted them to 40 and the hot weather pushed them to 44 today. I haven't noticed any difference in the ride and they haven't sprung any sudden leaks. There are many guys on here running high psi and they haven't had problems, but remember that you do all tests/mods at your own risk.
95metro is offline   Reply With Quote
Old 05-16-2006, 05:35 PM   #23
kickflipjr's Avatar
It's nice to see a gas log
It's nice to see a gas log with a ton of entries in it.
The 185 with tires on the aveo can hold 35-45psi with no problems.
2008 EPA adjusted:
Old 05-16-2006, 05:57 PM   #24
zpiloto's Avatar
Welcome.
Welcome.
I agree that if you really want to see big gains in milage a scangauge or other type device is a must. You can improve your milage without having to spend a lot of money just look through the forums and start working on your driving techniques, that doesn't cost a thing, then you can start with the aero and other mods.
Old 05-27-2006, 08:18 AM   #25
tvent's Avatar
Just wondering if kickflipjr took the aveo for a drive and what was the mpg?
tvent is offline   Reply With Quote
Old 05-27-2006, 09:17 AM   #26
I believe it was 37 or something like that, he made a thread in the general FE section.
Old 05-27-2006, 09:45 AM   #27
I would recommend switching all fluids to synthetics. More power, getter drivability especially in the cold, longer coasts, longer life of your car, cheaper since they last longer, better for the ecology.
Kevin A Thornton
KAT Automotive
For Speed Equipment, Nitrous Express
katman@everestkc.net
For AMSOIL products
https://www.lubedealer.com/kat
For Herbs from the Amazon
https://www.168336.amazonherb.net
GasSavers_katman is offline   Reply With Quote
Old 06-21-2007, 03:46 AM   #28
Hi I live in South Africa and have an Aveo sedan LT 1500 8 valve manual transmission. It is underpowered and thirsty. It takes a long time to fill the tank to the brim so one tends to get incorrect reading when trying to work out fuel consumption. Also the suspension is noisy. It has much more room inside than a VW Golf or Polo.
GasSavers_wigs is offline   Reply With Quote
Old 06-21-2007, 07:49 AM   #29
Hi wigs, welcome to the site.
I hear you about it being thirsty. In Canada, the Aveo has the worst fuel economy in the available B-car segment, according to government ratings.
People often say, "well it's a Daewoo", what do you expect? But GM and its partners have owned 67% of Daewoo since 2001, so you'd think they would have decided to try a little harder by now...
Old 06-21-2007, 07:59 AM   #30
zpiloto's Avatar
I
Hey I resemble that remark.
Welcome to the site
Verify your tripmeter/odometer accuracy... jcw74801 General Fuel Topics 15 11-10-2012 03:29 AM
How do I start? Enter my first fuel up? thirtythreedragons Fuelly Web Support and Community News 2 10-07-2009 07:18 AM
New homepage Matt Timion Fuelly Web Support and Community News 11 08-02-2006 04:21 PM
A Giblet of Friendly Advice SVOboy General Maintenance and Repair 12 08-02-2006 12:35 PM
1995+ Metro Front Brakes 95metro Experiments, Modifications and DIY 15 07-04-2006 03:12 PM
