Hi I'm Mike and I'm a Gasaholic... - Page 2 - Fuelly Forums
Old 09-10-2007, 05:05 PM   #11
Hi Mike, great intro!
Old 09-11-2007, 05:23 PM   #12
Hockey4mnhs's Avatar
welcome to the site! That is a huge jump in such a short time great job.
Old 09-12-2007, 10:20 AM   #13
lovemysan's Avatar
Originally Posted by oneinchsidehop View Post
50? My goal is 65 cruising and @ 100 P&G. May have to change cars but that's the goal.
switch to a 99 or newer saturn sl1, add HAI+scangauge. Drive 38mph= 65mpg.
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 09-12-2007, 11:33 AM   #14
oneinchsidehop's Avatar
I've had a couple of Saturns, SL1 and SL2W, what changed in '99? (they're for sale cheap up here A LOT) And whats a HAI?
Mike
_______________________________________________
"If you want to save gas I suggest you permanently remove the drivers seat and steering wheel. That seems to help." -Oscar Halverson
oneinchsidehop is offline   Reply With Quote
Old 09-12-2007, 11:36 AM   #15
HAI = hot air intake. One of the tricks that commonly works on the saturns.
Old 09-12-2007, 12:18 PM   #16
lovemysan's Avatar
somewhere between 97-99 the transmission for the sohc was changed to a taller overdrive. I'm not exactly sure. Cheapybob has a 97 and I believe he has the shorter gearing.
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 09-12-2007, 12:20 PM   #17
lovemysan's Avatar
here is my HAI
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Old 09-12-2007, 01:12 PM   #18
cfg83's Avatar
oneinchsidehop and lovemysan -
Here is your best reference for Saturn Gear Ratios :
Gear Ratios for 91-02
http://www.differentracing.com/tech_...gearratio.html
Old 10-18-2007, 10:20 PM   #19
Originally Posted by skewbe View Post
Hi Mike!!
Yah, I don't know why the subys get so low mpg, they are small enough cars. Good to know that they respond to P&G!!
I believe the BIG problem with Subarus is weight. Most of them weigh 3000+ pounds - not exactly high fuel economy material.
Old 10-19-2007, 02:45 AM   #20
Bingo! It's a porker. Small, but heavy. It's the hills that kill my FE, it's a lot to haul up to the top even if you do get to coast back down. It weighs @ 1000lbs more than I'd like.
Mike
