Hi from Northern CA. - Page 2 - Fuelly Forums
Old 12-16-2009, 09:25 PM   #11
GasSavers_JoeBob's Avatar
Originally Posted by rgathright View Post
Ha! Never trust the on-board MPG's! Scanguage turns driving into a videogame.
I don't know about that...the onboard MPG in my Cad runs fairly close (not exact, but close).
It'd be interesting to see a comparison between the onboard MPG and the Scangauge...to bad my car is too old for that...
Old 12-17-2009, 06:31 PM   #12
MyQ45's Avatar
It'd be interesting to see a comparison between the onboard MPG and the Scangauge......
my reply would be, why would Infiniti, in their flagship sedan, send less reliable information to the onboard MPG, than the information being sent to the OBDII port? seems silly....
I have installed aftermarket mpg systems (20 yrs ago) that were not accurate but I really think the info being fed is consistant and accurate.
with that said, I AM running 255 and not 245/45/18 tires so I know that it is off. But I'm ok with that beacuse I did not bother to have the system recalabrated.
I am looking forward to all the other functions though!
MyQ45 is offline   Reply With Quote
Old 12-18-2009, 03:21 AM   #13
There's no motive for manufacturers, including Infiniti, to make their MPG display particularly accurate. However, there's no reason for them not to, either. I'd guess that its accuracy depends mainly on their engineers and how they put it together.
There is no MPG information that goes to the OBDII port. There's not even fuel rate. Speed, at least, goes to the OBDII port. Things like the ScanGauge have to guess by calculating from other known factors what the fuel injection system is likely to do. It probably uses MAF, O2 and IAT to calculate its fuel rate guess.
Therefore, a Scanguage is likely to never match an OEM MPG gauge exactly, since the OEM unit probably has access to fuel rate data.
Old 12-18-2009, 11:46 PM   #14
On my Cad, one of the things you can see on the computer is the injector pulse length, in, IIRC, milliseconds. This may be what it uses to calculate fuel flow rate. Does OBD II provide, and does Scangauge show similar data?
Old 12-19-2009, 12:00 AM   #15
No. OBDII does not provide injector pulse length, duty cycle, or any other way to directly measure even relative fuel rate. There may be manufacturer-specific extensions that do but the ScanGauge (and other OBDII equipment without manufacturer-specific extensions) cannot access them.
lock nut removal tool? GasSavers_BEEF General Discussion (Off-Topic) 23 09-29-2008 06:53 PM
grill block getting on my nerves GasSavers_BEEF General Fuel Topics 22 07-28-2008 03:51 PM
Exhaust Options ravenrollercoaster General Maintenance and Repair 3 03-20-2008 06:58 PM
window defrosting methods? lunarhighway General Maintenance and Repair 32 12-06-2007 07:03 AM
Better gas mileage for an RV 73challenger General Fuel Topics 5 10-31-2007 05:08 AM
