09-20-2007, 05:54 AM
Member
The car is code free and running well. I've been thinking about doing VX in a 1st gen civic. Here is a few pictures of my 78.
http://forums.beyond.ca/st/35664/1978-honda-civic/
10-23-2007, 10:34 AM
Member
Hey.. My friend has been driving my 89 dx (vx engine) and it’s only getting 35-38 mpg city. I was hoping for more. I told him to shift under 2500 rpm.
I think the real problem is the DX tranny. I can’t use the vx tranny because it uses a hydraulic clutch system. HF crx's are rare in Canada, I have only seen one in my life.
Does anyone have a HF tranny for sale? (I'll make a post in the marketplace.)
Thanks,
10-23-2007, 10:41 AM
The HF tranny should help a bunch...I wonder if something else is up though...
I don't know anyone selling on right now, but you should be able to dig one up, good luck!
10-23-2007, 03:40 PM
I would not be surprised if the ecu isn't going into lean burn mode, because the rpm isn't low enough, for the speed. Their is a thread a while back which explains how to use a voltmeter to monitor the oxygen sensor, to tell when the engine is going into the lean burn mode. Without the engine going into lean burn and with a DX transmission, that mileage is probably about what your going to get.
I would have your friend drive it with the rpm at or under 2500 and see how it does. I would think that he could still drive 50 or so and get the controller to allow it to go into lean burn.
On your transmission, you should be looking for an 88-91 HF transmission. The 89-91 will work, but you will need a pressure plate and clutch to go with the year of the transmission, which may not be an 88.
10-23-2007, 04:07 PM
Welcome! I used to live in Calgary, but probably before most members here were born.
Your car is cool. Please post some more photos and would appreciate it if you could provide details (engine mounts, axles, etc) on what it took to get the VX engine in your car.
10-23-2007, 05:19 PM
Member
Well I parked my s2000 so I'll be driving the civic. I'm not sure if my friend "babied" it.
I dont really care what year HF tranny I get, I have several clutch sets. This DX tranny revs @ 3000ish at 60mph ...damn!
I used the dx axles and mounts. You need to modify (trim) the timing belt cover so you can use the engine 89 civic bracket. Other than that it drops right in. The wiring was crazy.. I think I added 14+ wires to the ecu.
4 - the dpfi to mpfi
2 - vtec
5 - 02 sensor
1 - egr * plus I tapped in 2 wires (from the tps) for the + and -
2 - egr box
? umm.. I'm sure there is more!
I'll have to take more pictures, feel free to ask any questions! Mrmad when did you live in Calgary?
10-23-2007, 05:23 PM
I saw your car going back from the airport today. Little red 78ish Honda. Cutest little thing! Was impressed in how good shape it was in.
three stripes the charm!
10-23-2007, 05:39 PM
2 - vtec
5 - 02 sensor
2 - egr box
Thanks for the info. If you get a chance, please take a bunch of photos. I lived in Calgary from 65-69, then moved to Edmonton. In 73, we moved to the US. Got rid of my Canadian accent unless I talk to some relatives for more then a few minutes.
10-23-2007, 05:53 PM
#19
have to be a member of that site to see the pics
10-24-2007, 05:02 AM
#20
35-38 city normal driving is pretty good. It takes a little time to adjust your driving style and get the mileage up. Driving style is the single biggest mileage improver. I found that over time my shift rpm dropped from 2500rpms to 1300rpms.
Also you might consider a superMID.
