Hi all
thanks for the warm welcome!
first of all the fuel prices (sorry for european measures, but i didn't want to risk conversion errors)
i think fuel is quite expensive here, mostly due to high taxes:
- super 98 = 1.304?/L
- super 95 = 1.293?/L
- diesel = 1.029?/L
- LPG = 0.475?/L
the first 2 kinds are petrol and 98 and 95 stands for the octane level. my car uses 98 wich is recommended for the engine.
the car still has the original paint job, though i believe it did spend more time indoors before i acquired it about a year ago . the color is some kind of glossy metalic blue, it seems to hide dirt very well too
yet i try to give it a regular cleaning.
the kadett e was quite a longlived model being in production from 1984 till 1993 and was indeed also sold as "Pontiac LeMans". later the model was picked up by daewoo "nexia". in 1985 the car was voted "car of the year" and received praise for its good aerodynamics. the only real downside to these cars is they tend to rust at the rear wheel wells...
as far as the carburator swap goes... it was more a matter of repair than an effort to improve the car... in fact the 2 carbs are alost identical.. the venturi is the same size but the fuel jets are slightly bigger now... they're should be interchangable so if my FE suffers to much i might revert to the original jets.
the fuel regulator screw was worn out on the old carb so despite running ok, it was difficult to adjust.
the car definately has more power now, so i'll see by how much my fuel consumption will chage (tank is almost empty so by the end of next week i should have a first result)... generally i agree that this mod will not improve the FE directely, but since the car is fairly heavy i imagine getting it up to speed faster might be an advantage...
i've kept a fuel log over the last year and although it's not very precise it gives a generally consistent picture.
i'm looking forward to exchage some more info & ideas in the appropriate threats
