Hey everyone! - Page 2 - Fuelly Forums
Old 03-26-2006, 08:17 PM   #11
mtbiker278's Avatar
Re: Quote:if you want to keep
Originally Posted by SVOboy
ell, the civics might even be 5 lug now!
They are 5 lugs now. I'm ot sure where I'd want to go with any mods as of yet. Stuff that comes to mind would be intake, exhuast, maybe pulleys. From what i've seen so far there isn't any conclusive data that says any of those would increase MPG. However they would increase HP. In which case I'd probably have to go with a turbo, LSD, coil-overs, a ridiculous wing...
The bottom line though is I have limited funds, so i must stick with smaller inexpensive mods.
mtbiker278 is offline   Reply With Quote
Old 03-26-2006, 08:17 PM   #12
mtbiker278's Avatar
They are 5 lugs now. I'm not sure where I'd want to go with any mods as of yet. Stuff that comes to mind would be intake, exhuast, maybe pulleys. From what i've seen so far there isn't any conclusive data that says any of those would increase MPG. However they would increase HP. In which case I'd probably have to go with a turbo, LSD, coil-overs, a ridiculous wing...
Old 03-26-2006, 08:18 PM   #13
mtbiker278's Avatar
note to self, don't press
note to self, don't press the back button
Old 03-26-2006, 08:30 PM   #14
Try out a warm air intake
Try out a warm air intake and hotter thermostat.
Old 03-26-2006, 08:56 PM   #15
Matt Timion's Avatar
Re: Try out a warm air intake
Warmer thermostat is definately the way to go. It will run around $10 and is easy to install if you have a little technical ability.
Oh, and welcome to the site.
Old 03-26-2006, 11:02 PM   #16
Compaq888's Avatar
I went with NGK copper spark
I went with NGK copper spark plugs(V power). Everybody said they are better. I'm also using Royal purple.
I can do 30mpg if I try, but so far I'm doing 25mpg due to racing and high speed driving.
The new civic is great, especially the auto. It drives at 2500rpm at 80mph, which is impressive. It handles good too. I had a chance to drive both the sedan and coupe, both auto. The car has a good amount of torque, really likes top end. After the car breaks in around 15k you should get a small mpg boost. Then change to synthetic.
2013 Sentra EPA & dashboard readout vs. actual gas mileage smithfam7 General Fuel Topics 8 08-17-2013 07:28 AM
Add gal/100 mile display wnshall Fuelly Web Support and Community News 9 07-11-2012 11:10 AM
Suggestion: Numbered tanks MMUK Fuelly Web Support and Community News 5 10-19-2011 08:07 PM
Accuracy of Fuelly otherpower Fuelly Web Support and Community News 6 11-17-2010 08:58 PM
Hydrogen Generator! SVOboy General Fuel Topics 208 08-06-2006 03:59 PM
