Hey! - Fuelly Forums
Old 07-17-2010, 09:53 AM   #1
Hey!
I just wanted to say I just joined gassavers.org. I've been following this site for a while now and I decided to finally join. I have a 1990 Civic DX Hatch, and I've been doing a few modifications to it. Hopefully as I get more used to this site I'll find more stuff and be able to share it as I do it.
I'm very happy with my grill block:
Attachment 1719
My wheels are normal, cheap pvc wheel covers with polyurethane foam to fill in the gaps and putty to fill in the gaps in the poly. Then truck-bed black spray to top it all off. A lot more work than it should have been...
Attachment 1720
And here's what it looks like in general:
Attachment 1721
Attachment 1722
I put in the CAI because it really gave a noticeable boost in hp...but I didn't notice drop in FE. The DPFI really helps keep mileage down, but especially in low gears, I like the slightly higher performance if I need quick acceleration.
Name:	Grill Block.JPG
ID:	1438   Click image for larger version
ID:	1439   Click image for larger version
ID:	1440   Click image for larger version
NeoCivic is offline   Reply With Quote
Old 07-17-2010, 10:00 AM   #2
i-DSi's Avatar
Welcome Neocivic!
What's your mpg (evolution) with all these modifications?
i-DSi is offline   Reply With Quote
Old 07-17-2010, 10:09 AM   #3
Re: Evolution
This car started out (combined) about 34-36 when I first got it (155,000).
Since most of the mods are aerodynamic, I notice a big boost if I'm driving highway, and I've gotten upwards of 58-60 on all-highway.
But generally I'm driving around in Kent, WA, which, if you've been there, you know it's divided in half by a huge valley. So city driving takes a hit. As of my last fill-up, though, I've been getting about 45-46 mpg in 3/4 city driving, which I'm really happy about.
I just began pulse and gliding leaving the car on and in gear because I've noticed, through my air/fuel gauge, that it burns super lean or even no fuel at all when it's coasting in gear.
Anyone ever pay attention to the gap between the windshield and the rubber apparatus that holds it? I've experimented with filling that in...the front window on my civic starts making noise around 50-55 mph. That's gotta have an effect. Maybe that'll be my next thread.
Old 07-17-2010, 10:17 AM   #4
i-DSi's Avatar
Originally Posted by NeoCivic View Post
I'm driving around in Kent, WA, which, if you've been there...
Ha, ha, you've got the right spirit! I'm living in Belgium.
But your result is fantastic. Congratulations.
Old 07-17-2010, 11:07 AM   #5
Lean Burn Mode
pgfpro's Avatar
Nice work and welcome to the site!!! I just came from the Kent Seattle area. It was great weather there,not to cold and not to hot.
Old 07-17-2010, 02:30 PM   #6
I love the idea with the wheelcovers. Too bad the result wasn't better, but it's still a great idea, just might need some work to smooth it out more. Has it affected your wheel balance at all, or did you do a well-balanced job of it?
That's called Deceleration Fuel Cut Off or DFCO, and most fuel-injected vehicles will do it under some conditions.
I call that Pulse & DFCO. In my car it was less efficient than just plain steady cruising. I found it also to be an intolerable way to drive, constantly accelerating and decelerating at that level.
However, it sounds like your routes often include long descents; DFCO is perfect on long descents.
I've asked about it and it seems like that area isn't as important as it looks, as it's a low-pressure area from the slope change between the hood and windshield.
Old 07-17-2010, 08:01 PM   #7
Have fun with it Neo! My '91 Sedan is closing in on 300,000 miles...
~Bill
Nrggeek is offline   Reply With Quote
pollution while driving Erdrick General Discussion (Off-Topic) 10 11-01-2007 12:11 AM
Using boost for mileage MY02WRX General Maintenance and Repair 19 10-23-2007 09:46 PM
Introducing DMC Compaq888 General Discussion (Off-Topic) 26 08-07-2006 12:13 AM
Hydrogen Generator! SVOboy General Fuel Topics 208 08-06-2006 03:59 PM
