Hello from Noobie owner of a 92 Civic VX - Page 2 - Fuelly Forums
Old 09-26-2007, 07:55 PM   #11
Junior Mint
dogncatboy's Avatar
Its a 92 and from what I read the vtec-e thing wasn't on there til 94 & 95, but I could be wrong. The engine block is properly stamped and all the parts seem to fit a VX including the 5 wire O2 sensor. I ran through this in a different thread. See http://www.gassavers.org/showthread.php?t=5149
Thanks though, I appreciate the comps! I think she's a real gem. I'll be real happy once I straighten the FE out. If I can get 50 I'll be happy. It's running on the wrong plugs now and I'm changing them tomorrow. I'm hoping plugs will help.
... D'oh!
dogncatboy is offline   Reply With Quote
Old 09-26-2007, 08:04 PM   #12
1993CivicVX's Avatar
I'm pretty sure mine doesn't have the VTEC on it, but I'll check tomorruh. Actually, my car is going in for some rust repair so it can pass inspection (still haven't got it inspected since I bought it!)
three stripes the charm!
Old 09-26-2007, 08:07 PM   #13
GasSavers_TomO's Avatar
Couple things I'd like to add to that How-To:
When measuring the voltage on the TPS, you don't need the car running, just the ignition to "on/run"
Secondly, once you have the voltage set to .45V (slightly below that is fine too) Have someone press the gas pedal all the way to the floor (this is why I set my TPS with the car just in the run position) and make sure that the voltage goes above 4.5V and below 5V.
On the valve cover thing..All VTEC motors in 92-93 did NOT have VTEC (or in our cases VTEC-E) on the valve covers. This was a 94-95 deal for our cars.
When I first got my VX it had the ZFR5F-11 plugs in it and had a low RPM stumble something fierce once warmed up. It went down to being the normal power stumble upon acceleration once the correct ZFR4F-11 plugs were installed.
Honda Civic VX Info/Links
Old 09-27-2007, 05:38 AM   #14
Junior Mint
dogncatboy's Avatar
Many thanks for the detailed info. I will check it out once the rain vamooses! I hope I'm in the ballpark so I don't have to back this out.
... D'oh!
Old 09-27-2007, 08:12 AM   #15
Danronian's Avatar
If the aforementioned fixes don't work to fix your idle problem, it could also be that the IACV or EGR are clogged and need to be cleaned out. I know on the 120k mile VX motor I installed in my civic, the IACV was pretty much clogged.
Good luck with the car, and it sounds like you got a great deal on it!
Old 09-27-2007, 10:21 AM   #16
smccall's Avatar
Welcome to the site. I'm a noobie too but your a many steps ahead of me being that I'm stilling looking for a VX or CX. Hope you MPG get better with the new plugs.
Old 09-28-2007, 07:16 AM   #17
Junior Mint
dogncatboy's Avatar
IACV? Whats this and where do I find it...
Been looking at the schematics and can't seem to locate the bugger. If any one can toss the dog a bone, it'll be much appreciated. Thanks.
...Good luck Smccall, it took me some weeks to locate one. Be vigilant and check daily, nothing worse than getting to a listed VX a day late and having it gone.
... D'oh!
Old 09-28-2007, 08:37 AM   #18
Consider the bone tossed...HERE
Old 09-28-2007, 10:14 AM   #19
http://sacramento.craigslist.org/car/433256087.html
Click the above link. It is a 1992 Civic VX. Scroll down to the pics. You'll see a pic of the engine with the vtec-e cover. I'm pretty sure mine doesn't have it though. But this 1992 model apparently does. Although... the ad says 99% stock, and the vtec-e cover looks pretty clean so maybe it is a replacement part. Peanuts and argyles.
Old 09-28-2007, 01:56 PM   #20
Junior Mint
dogncatboy's Avatar
Thank you, thank you, thank you, thank you, thank you, thank you.... One more thing to do tomorrow morning!!!!
... D'oh!
Let the games begin! Matt Timion General Fuel Topics 4 12-11-2021 11:04 PM
Installed 195F Coolant Thermostat ... Reset ECU? cfg83 General Maintenance and Repair 13 04-06-2011 11:54 AM
2006 Toyota Camry LE rh77 Car Reviews 0 01-24-2007 07:17 AM
Finally got some LRRs rh77 General Fuel Topics 4 10-03-2006 08:16 PM
"Lean Cruise" ECU Modification Thoughts GasSavers_scostanz General Fuel Topics 12 07-11-2006 04:36 AM
