Hello from Noobie owner of a 92 Civic VX - Page 3 - Fuelly Forums
Old 09-28-2007, 02:00 PM   #21
1993CivicVX's Avatar
Originally Posted by dogncatboy View Post
Thank you, thank you, thank you, thank you, thank you, thank you.... One more thing to do tomorrow morning!!!!
I second that emotion. Thanks TomO! The ceaseless source of DIY.
three stripes the charm!
Old 09-29-2007, 05:10 PM   #22
cfg83's Avatar
dogncatboy -
Welcome to GS! As you can see, the VX Doctors are on the job.
Old 09-29-2007, 06:38 PM   #23
GasSavers_TomO's Avatar
I still wish Krousdb was here, he was a Whiz with all the vx stuff as well.
HERE is one of my bookmarks to check when thinking off DIY stuff for a Honda.
Honda Civic VX Info/Links
Old 09-30-2007, 05:46 AM   #24
Junior Mint
dogncatboy's Avatar
Thanks for the kind welcome and all of the help as well! My idle problem appears to be solved! Yesterday I calibrated the TPS, cleaned the IACV and installed the new O2 sensor. The idle is aabout 600rpm, a major improvement over the 1300rpm before the repairs. I'll find out next week how well she performs on the highway and I'll post an update as well as keep track in the garage. Before getting the VX 'd change oil and filters on my cars, now I think I'll take more repairs on in the future... at least on the VX. My Subaru has a lot more going on under the hood and I find that more intimidating. I love the simplicity of the VX engine compartment. Anyone know of a good Subaru repair site I can bookmark? Thanks again to everyone, I could not have done it without your help.
... D'oh!
dogncatboy is offline   Reply With Quote
Old 09-30-2007, 04:02 PM   #25
Maybe your car also have vacuum leak like mine. Read my thread under general tech title "Paid SVOboy a visit" for more info on that theory.
Old 10-01-2007, 10:41 AM   #26
smccall's Avatar
Congrats on the fix. Still looking for a VX though. I came across a 93 dx which was under $1000 and not sure if I should pull the trigger. The gas mileage isn't that close to a CX or VX.
Old 10-01-2007, 04:15 PM   #27
Junior Mint
dogncatboy's Avatar
I'll check it out. My problems aren't all gone. Idle is better, but still can't decide if it wants ~600 to ~1000rpm. I suspect a vacuum leak but can't find it, even went through 2 cans of starting fluid trying like heck to track it down. Thanks for the heads up.
... D'oh!
Old 10-01-2007, 04:36 PM   #28
I spent a lot of time chasing a similar problem on my 89 Honda Wagon. It ended up being the IACV valve was leaking a little air, when the valve was not energized and it was supposed to be closed. If you take off the valve, you should not be able to blow through the valve, with it not connected to anything. If you can, then you need to get a replacement.
Best of Luck.
Old 10-12-2007, 12:07 AM   #29
garyhgaryh's Avatar
Its a 92 and from what I read the vtec-e thing wasn't on there til 94 & 95, but I could be wrong. The engine block is properly stamped and all the parts seem to fit a VX including the 5 wire O2 sensor. I ran through this in a different thread. See http://www.gassavers.org/showthread.php?t=5149
Thanks though, I appreciate the comps! I think she's a real gem. I'll be real happy once I straighten the FE out. If I can get 50 I'll be happy. It's running on the wrong plugs now and I'm changing them tomorrow. I'm hoping plugs will help.
It looks like a vx engine.. Like mine - 93 VX.
My paint is also faded like yours. I need to repaint it.
Gary
garyhgaryh is offline   Reply With Quote
Old 10-12-2007, 12:10 AM   #30
garyhgaryh's Avatar
Originally Posted by TomO View Post
Consider the bone tossed...HERE
I took mine out to clean at 230k and it was clogged. Car idled rock solid before and runs even better now. With 230k my car still runs like a new car.
Gary
Let the games begin! Matt Timion General Fuel Topics 4 12-11-2021 11:04 PM
Installed 195F Coolant Thermostat ... Reset ECU? cfg83 General Maintenance and Repair 13 04-06-2011 11:54 AM
2006 Toyota Camry LE rh77 Car Reviews 0 01-24-2007 07:17 AM
Finally got some LRRs rh77 General Fuel Topics 4 10-03-2006 08:16 PM
"Lean Cruise" ECU Modification Thoughts GasSavers_scostanz General Fuel Topics 12 07-11-2006 04:36 AM
