Hello from Mississippi - Fuelly Forums
Old 12-11-2007, 08:02 AM   #1
Camaroguy's Avatar
I've got a Hotrod Camaro SS and I stumbled accross this gassavers.org in search of improving my fuel economy. Already, I will exchange my present cam a 228/230 112lsa with huge lift to a more down to earth 214/220 cam with a 116 +2 LSA custom designed cam to produce both power and fuel economy. Additionally, I have a fidanza aluminum flywheel that will reduce some rotating mass in the drive train. I'm also hoping to use some of your aero tricks to help the ole MPG.
[SIGPIC][/SIGPIC]2002 Camaro SS Big gas guzzeling cam, Ported Heads, 6-speed manual transmission, suspension work, air intake system, 4:10 gears, the car really is fast.
Camaroguy is offline   Reply With Quote
Old 12-11-2007, 08:03 AM   #2
lovemysan's Avatar
Sweet ride. I love big cam small blocks. Any videos?
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 12-11-2007, 08:14 AM   #3
Camaroguy's Avatar
I had to dig a little but here is a video of the car.
http://videos.streetfire.net/video/4...A621DE0DAF.htm
Old 12-11-2007, 08:24 AM   #4
Camaroguy's Avatar
Here are all the goodies on the car....a signature line from a z28 forum.
2002 SS 6sp - TR 229/231 647/593 lift 112 lsa, PRC CNC ported LS6 Heads, LS7 Clutch kit, SVO 30#,TR Ported Throttle Body, BMR Throttle Body bypass, SLP Air Box, SLP Cold Air Induction! Pacesetter LT headers, Texas Speed 3 inch Catted Y pipe, Magnaflow Cat-Back exhaust, SLP Strut Tower Brace, BMR Torque ARM, BMR control arms, lowering brackets, Panhard Bar, and SFC's, PCMforLESS Tune, 160 thermostat, AAM 4:10's, Nitto DR.
Old 12-11-2007, 09:23 AM   #5
CoyoteX's Avatar
swapping out to different gears will help more than the cam swap. And find some eagle GS-C tires that came stock on the car, they are about the best low rolling resistance tires you can find for the sizes on these cars.
Mine has a 110 degree asa cam, 3000 stall 4spd auto, 2.73 gears and I still get 24mpg. when stock I got 28mpg normally.
Just using the skip shift that came with the car and trying to keep the car smooth and easy should get you over 20-25mpg without much effort as long as the gearing isn't making it rev high on the highway. 1500-1800@65mph is what mine does if I can remember it right.
Old 12-11-2007, 09:35 AM   #6
Camaroguy's Avatar
Thanks Coyote! I already bought the cam and the flywheel...so I'll install them. I still have my 3.42 gears and I will see what kind of improvements I can get before going back to them. But I need to get a base line first.
VX in Maine.... UfoTofU For Sale 4 01-27-2007 12:12 PM
Yeah... O.k. omgwtfbyobbq General Discussion (Off-Topic) 1 01-16-2007 08:41 AM
