Hello from a VX owner! - Fuelly Forums
Old 08-30-2007, 01:43 PM   #1
Danronian's Avatar
Hello everyone!
My name is Dan and I my current car is a 95 Civic VX.
I didn't buy the car since it was great on gas, but because it was a great deal, is my favorite car color, and was worth more than the asking price.
In around March, I got rid of my old car, a 1995 Acura Integra LS, to go with something that wouldnt be as profiled by police (I am a very safe driver, but was given a bogus ticket last September that ended up costing me $800 in the end...), and less likely to be stolen.
The car was just painted when I got it, but the body work was not done very well. I am accustomed to doing body work, so I didnt really see this as a problem, since this car is only a daily driver, and the body work is something I can fix when the current work decided to bubble and fall apart. The car had 238k miles on it when I bought it, and I could tell it had a hard life before it came into my hands. The car has Bondo work in most of the panels of the body, the interior was partially painted yellow, it had the wrong seats installed in it, it had a small electrical problem (due to a wire that rubbed through going to the front corner light), and it smoked a little bit. Luckily, much of the suspension on the car was replaced before I bought it, and the very pricey wideband 02 sensor.
After owning and driving the car for about 2 months and 4k miles, I decided I was going to replace the motor with a non-smoking one, and also fix everything else wrong with the car, along with replacing the clutch for good measure. (details of the work are in my garage)
The mods on the car when I got it, are the same ones on it today.
These include:
Stainless Apexi WS2 Exhaust (very quiet)
Short-ram intake and K&N Filter
Performance struts and adjustable coilovers
Antenna
Overall this is a great car, and I would like to get even better gas mileage out of it. So far my best combined is 45 mpg, but I have heard of many people getting over 50 mpg with these cars.
Here?s some pictures:
New car next to my old car:
The best picture I have of the finished outside and inside product:
Cleaning the engine bay and fixing the small wiring problem:
2nd day I owned the car:
The old motor out:
Old 08-30-2007, 01:48 PM   #2
mrmad's Avatar
Welcome, look around here for tips how to get your mpg higher, your car certainly has potential. When you say it was a good deal, how much $ did you pick the VX up for?
Old 08-30-2007, 02:01 PM   #3
1993CivicVX's Avatar
Yeah I'd like to know! as I just became the happy owner of a 1993 VX with 175k miles and a few problems but otherwise in good running order for $1800
three stripes the charm!
Old 08-30-2007, 08:28 PM   #4
Danronian's Avatar
I picked this one up for $2000 in North-Central PA...in Sayre to be exact.
These civics are very hard to find in my area near Philly for this price, especially the VX models with most of the VX stuff still intact.
With new paint, two good tires, and much of the front suspension replaced, this was a pretty good deal.
Old 08-31-2007, 07:34 AM   #5
GasSavers_TomO's Avatar
Welcome aboard fellow VX owner! My VX was originally teal colored as well, but I couldn't stand it, lol. not to mention I had replaced damaged body parts with ones from a milano red Hatch...it didn't look pretty, so I painted mine Navy Blue, similar to the color the DX hatches were available in.
Honda Civic VX Info/Links
Old 08-31-2007, 10:36 AM   #6
I love the color of mine. Wasn't something I thought about when I bought it, but when I noticed the color I noticed I liked it. I have a meeting with my mechanic to talk about all the tips and advice I've picked up from this forum and this forum and what he thinks the best way to approach the hesitating acceleration. Thanks TomO for all the help so far.
Oh, while I'm here, and maybe this will be useful to you do Dan, do I risk wrecking my car if the timing belt breaks on it? I don't want to have the mechanic check if it needs to be replaced if it doesn't need it (the last owner who put 30,000 miles on it did not replace it) but if I run the risk of wrecking the car then maybe I better do it! Any thoughts on that one TomO?
Old 08-31-2007, 05:40 PM   #7
Danronian's Avatar
Yes. Replace the timing belt. Chances are it was done at 100k miles, and now it will need it done soon anyway. If it snaps, chances are, you will bend valves, and your engine could become ruined. It is both cheap to replace in parts and is easy to do if you want to devote some time to doing it yourself.
Good luck with your VX.
Old 09-01-2007, 02:54 PM   #8
I agree with Dan on the timing belt. On ANY honda I buy (unless it's from a close friend) I replace the timing belt right away along with a tune-up.
Old 09-01-2007, 07:29 PM   #9
Sigifrith's Avatar
Tom shouldn't he do the water pump at the same time?
[SIGPIC][/SIGPIC]
Sigifrith is offline   Reply With Quote
Old 09-03-2007, 07:23 AM   #10
Danronian's Avatar
And the timing belt tensioner should also be replaced. Sometime you can get away with not replacing them, but if it ends up making noise later, you will regret it.
When doing the timing belt it's also a perfect time (if you're willing to take the time) to adjust your valves since having them adjusted correctly will help with the engine's efficiency at least slightly.
I also generally inspect and/or replace the accessory belts at this time (since they need to come off).
As for the brand of the timing belt...
If you will be paying a lot to get the timing belt and water pump replacement done, I would go with Honda parts since they will last the longest. If you're doing it yourself, I would go with something cheaper (since any other brand will be cheaper) But if you do pick the other brand, I wouldn't push off replacing it next for 100k miles, but instead replace it around 70 or 80k mi just to be safe it won't snap on you. I never hear of the Honda belts snapping or the water pumps going bad at anything less than 100k miles, but the off-brands seem like they tend to do it sometimes.
« Yukon Ho! | hi! »
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 10:54 PM
Are new cars magnetic or something? Silveredwings General Discussion (Off-Topic) 64 11-03-2009 05:23 AM
New member from Akron Ohio, 2001 Saturn Sl1 Golf3r Introduce Yourself - New member Welcome 28 04-10-2007 03:22 PM
Vortex Generators / Hmmm Airtabs zpiloto Experiments, Modifications and DIY 92 02-09-2007 07:26 PM
