Hello! - Page 2 - Fuelly Forums
Old 07-19-2011, 01:48 PM   #11
Re: Hello!
P&G without neutral (I called it Pulse & DFCO) was worse than steady driving in my 2008 VW, and logically it would be worse in any car.
HC,
i'm still learning my civic(had it only a few months), but i'll have to disagree here. i've tried both cruise control and P&G w/ DFCO, and at high speeds the latter yields a few more MPGs...scan gauge and fill ups both confirm.
Old 07-19-2011, 03:02 PM   #12
Re: Hello!
Interesting. I wonder how it works.
Old 07-20-2011, 11:38 AM   #13
FrugalFloyd's Avatar
Re: Hello!
Any benefits from cruise control v. P&DFCO would have to be minimal: the difference between gph at cruising speed v. avg of BSFC combined with drivetrain drag. Doesn't seem reasonable to me, either.
Old 07-20-2011, 01:56 PM   #14
Re: Hello!
tank to tank would be difficult to determine, but scangauge confirms a 3-4mpg difference on. the test speeds were 60mph(cruise) vs 65 to 55(P&G w/ DFCO).
Old 07-26-2011, 09:49 AM   #15
Re: Hello!
so are we basically saying that cruising at 60 is the best fe??
grsshpr1 is offline   Reply With Quote
Old 07-26-2011, 10:29 AM   #16
Re: Hello!
For open freeway driving, cruising at 60 is decent. Gains could be found using DWL, pulse & glide (neutral), pulse & EOC (given rolling hills), or drafting.
That said, on the freeway P&G or P&EOC is too much work for too little gain unless your car is dense and very aerodynamic. I EOC down one freeway hill on my commute but otherwise I do something similar to DWL (DWL doesn't apply on my carbureted car but I keep a target vacuum level in mind).
Old 07-27-2011, 08:04 AM   #17
Re: Hello!
Cruising at the slowest speed you can gets you the best no-effort fe. 55 mph beats 60 mph, 50 mph beats 55, and 45 mph beats 50. So pick the road with the lowest posted speed limit, and drive at that speed, or 5-10 mph below the PSL, if there's no other traffic to impede. On cruise control, I get 50-55 mpg at 30-35 mph, 40 mpg @ 55 mph, and 32 mpg @ 70 mph.
P&G beats steady speed cruising. It adds ~5 mpg on highway trips, and 10-15 mpg under city/country road conditions. I get 45-52 mpg P&G between 50-60 mph, 55-65 mpg between 25-40 mph, and 60-72 mpg between 20-30 mph.
