Explorer 4.0's Owner From Pa - Page 2 - Fuelly Forums
Old 11-09-2007, 01:54 PM   #11
TeamExploder's Avatar
Send a message via AIM to TeamExploder
thanks for the welcome's folks!
96 Ford Explorer XLT Auto 4.0 OHV 4X4
98 Escort ZX2 Sport 2.0 DOHC 5spd.
99 Chevy Malibu 2.4L Auto
TeamExploder is offline   Reply With Quote
Old 11-09-2007, 03:06 PM   #12
GasSavers_Red's Avatar
Does the 92 have manual hubs or a part time t-case? Any chances of swapping to one?
Old 11-09-2007, 03:06 PM   #13
Danronian's Avatar
I asked him tonight and he said it avgs around 19-20 if he goes on the highway, and around 16 on back roads... Doesn't sound too good to me. I told him to add a little psi to the tires for some better mpg, so maybe that will help him a little.
Old 11-09-2007, 06:05 PM   #14
Red: My 92 does have manual hubs and a part time t-case, its push button so you can have it in 2wd when you want or 4X4 hi or low, or you can have your 2low if your hubs are unlocked. And what were you meaning by swappying to one?
Danronian: It is somewhat good to have the tires inflated more, but gotta remember the whole Firestone explorer cases, impropper inflation in tires on these trucks can blow out because of the weight and being top heavy also plays a factor. I keep around 35PSI in both my explorers
Old 11-09-2007, 09:00 PM   #15
Yep, that what I meant. I want manual hubs.....
Old 11-09-2007, 11:33 PM   #16
Danronian's Avatar
I think he put around 38 in his...
Yeah, they are top-heavy, but not as bad as my mom's Tracker. They are some of the easiest to flip SUVs out there.
But yeah, I think that firestone issue was with underinflation and the tires overheating because of it...but I don't really remember. I think he said the doorjamb said something like 26 psi, but with that in there, they tires looked nearly flat.
Old 11-10-2007, 06:00 AM   #17
Hubs
Red,
The older Explorers generally had a conventional transfer case (electrically shifted by pushbutton) and "automatic" hubs. The hubs would only engage when 4X4 mode was engaged and would release when next you reversed direction in 4X2 mode. Manual hubs were available, as was a lever-shifted transfer case but were very rare. Manual hubs are very commonly and easily retrofitted in place of the automatic hubs, but offer no improvement in terms of 4X2 drag/fuel economy. They're more durable.
Original Poster: Your dad's mileage sounds pretty typical. Our '94 Explorer with 5-spd manual never got more than 22 mpg on the highway; more commonly ~20-21. Our '99 Mountaineer is 5-spd automatic with the OHC V6 and gets about the same. We found that the ride got very harsh above 31 psi.
css28 is offline   Reply With Quote
Old 11-10-2007, 06:06 AM   #18
Thats true....lever shift transfer case were usually more available in the XL models, but rare in them too, the"automatic" hubs were junk in the 91-94 explorers, can't really depend on them. Our 96 has the "auto" hubs but I think they're more of a all-time lock-in. I don't know much bout this newer explorer just yet since its my first, but the fiance drives is going to drive this one in the winter so I wont switch them to manual hubs just because it will be more convenient for her.
Old 11-10-2007, 08:37 AM   #19
Ahh well it was a hope.
The "auto" hubs sounds like the vacuum disconnect setup in the YJs(88-95) Wranglers. Sometimes the shaft would disconnect more often then not it would just get stuck in its current mode.
Are new cars magnetic or something? Silveredwings General Discussion (Off-Topic) 64 11-03-2009 05:23 AM
Weight reduction - not always good? landspeed General Fuel Topics 59 02-29-2008 06:21 PM
PZEV in an older car? repete86 General Maintenance and Repair 0 02-12-2007 08:27 AM
Wow. Video of Portland icy road/fender benders MetroMPG General Discussion (Off-Topic) 17 01-21-2007 05:58 PM
I need computer help. Rstb88 General Discussion (Off-Topic) 3 01-07-2007 12:38 PM
