Civic VX, tuning the d15z1 VTEC E - Fuelly Forums
Old 12-18-2012, 08:30 AM   #1
Hello All, I have been getting excellent fuel economy from this d15z1 engine but it's leaking a bit of oil from the valve cover gasket and from the distributor o ring. I'm going to replace those and possibly the vtec solenoid gasket. It is running great and idles exceptionally well but I'm thinking that while I'm in there I should check and adjust the valves if they can use it. I'll probably replace the timing belt and water pump. Does anyone have tuning tips, especially regarding the VTEC E? and especially regarding adjusting the valves? Any info is greatly appreciated!!!
Wilcrass is offline   Reply With Quote
Old 12-18-2012, 02:09 PM   #2
Go to Honda Hookups you can download the fsm. Factory service manual.
Rusty94cx is offline   Reply With Quote
Old 12-18-2012, 07:48 PM   #3
Thanks Rusty!
I'll check it out!
$100 Civic VX 5 wire O2 / LAF sensor. will it work? GasSavers_ian General Maintenance and Repair 3 12-22-2012 08:24 PM
And America Has.......... shatto General Discussion (Off-Topic) 8 06-29-2010 04:18 AM
? for dmm user's, monitoring lean burn rlprlp1 General Maintenance and Repair 4 12-17-2007 11:16 AM
New Camry Hybrid... cool display! Matt Timion Hybrid Vehicles 6 01-19-2006 05:29 PM
