Camry to Civic - Fuelly Forums
Old 06-12-2008, 06:02 AM   #1
jprich's Avatar
Camry to Civic - Northern Virginia
Hello,
I drive 30 miles to work one way Mon-Fri. My 93 Camry was costing me too much in gas. So I did some research and slowed down, coasted, etc. My MPG went from 24 to 32mpg. Cant complain about that.
The Camry has a 15 gallon tank so thats around $55 a fill up ( as of early June in Northern Virginia ).
I wanted better so I found a 98 Civic LX. I picked up up yesterday from CarMax. Great car. Looks good, drives well except for the gas pedal sticks ( nothing I cant fix or have them fix ).
HOWEVER.
I got the trip odometer to 60 miles or so at work this morning and had just about 3/4 a tank. Not a good start.
Im driving it to Mrytle Beach, SC this weekend ( 7 hours or so ).
Tires are 50psi and I will be doing 63 mph with cruise the whole way.
I have 5 days to turn it back in with no penalty. So thats Sunday.
If the mpg doesnt improve on the trip down and back I will go back to the Camry.
Stay tuned!
jprich is offline   Reply With Quote
Old 06-12-2008, 06:21 AM   #2
1998 Civic may have a 12 gallon tank.
Old 06-12-2008, 06:54 AM   #3
jprich's Avatar
yep
11.9 per Honda specs
1993 Toyota Camry
4 Door LX
180+k miles
44 psi
65mph and below
EPA rated 18/26/21
32 mpg
45 mph/rpm sweet spot
15 gallon tank
$67.50 full tank @ $4.50 gallon
1998 Honda Civic
4 Door LX
112+k miles
50 psi
65mph and below
EPA rated 25/33/28
?? mpg
?? mph/rpm sweet spot
12 gallon tank
$54 full tank @ $4.50 gallon
35mpg is the minimum Im willing to accept from the Civic. Id like higher, closer to the 480 miles / full tank I get from the Camry.
Im hoping that the previous owners drove it mostly city to explain the crappy start. I may be jumping the gun. This weekend trip will give me an answer.
Old 06-12-2008, 07:11 AM   #4
suspendedhatch's Avatar
The fuel gauge is extremely inaccurate and not a good indication of the kind of mileage you will get.
When you buy such an old car you have to catch up to the maintenance schedule which undoubtedly has been neglected. Do a FULL tuneup. Distributor cap, rotor, spark plugs (get NGK or Denso), fuel filter, check base ignition timing, clean out throttle body, IACV, intake manifold, use seafoam in the oil, through a vacuum hose, and in the gas tank, check/replace lazy O2 sensor, check alignment, change oil and filter, transmission oil, change/clean PCV. Check spark plug wires. Replace charcoal canister. Replace in tank fuel strainer. On all my Hondas I like to get the injectors balanced and blueprinted.
You do all this and you should easily achieve 35+ mpg, pick up some pep, and enjoy a reliable, trouble free car for years to come.
Old 06-12-2008, 07:24 AM   #5
jprich's Avatar
Very true. Im going to have to do some just to get the gas pedal unstuck.
The Camry is paid for the Civic NOT. So thats why Im a bit gunshy.
Arco gas - mileage poor jbum General Fuel Topics 9 07-07-2013 11:25 AM
Looking for a VX in Montana cruiserdarren For Sale 4 03-08-2008 04:34 PM
Concentrating photovoltaics advancements ... cfg83 General Discussion (Off-Topic) 4 03-01-2007 06:24 AM
Just got my '95 VX whychug Introduce Yourself - New member Welcome 7 01-30-2007 06:24 AM
Is there room to track news stories...... ketel0ne Fuelly Web Support and Community News 3 08-01-2006 11:16 AM
