another yaris noob - Page 3 - Fuelly Forums
Old 08-23-2006, 06:57 AM   #21
schmeep's Avatar
nice, the only time i approached numbers like that (41+) was on a long trip, but most of my driving is short trips, so that is probably why.
schmeep is offline   Reply With Quote
Old 08-23-2006, 09:36 AM   #22
On the subject of grill blocks:
http://www.gassavers.org/showthread.php?t=701
http://www.crxmpg.com/grillblock.html
And some info'mation on drag:
http://www.tfd.chalmers.se/%7Elelo/r...on-to-drag.pdf
With the yaris it seems you could get a very slick thing going with a piece of coroplast mounted up there smooth with the rest of the body and painted to match (or just solid black).
Old 08-23-2006, 11:20 AM   #23
schmeep's Avatar
i just took a look at the grill and radiator, and i noticed that inside, the grill is blocked except for around the radiator. the block isn't flush with the grill but straight up and down around the radiator.
so this would be a grill block, already there?
Old 08-23-2006, 11:29 AM   #24
Picture time!
Old 08-23-2006, 11:37 AM   #25
An illustration would suffice.
Old 08-23-2006, 11:39 AM   #26
You're just begging him to work on stuff for you, aren't you?
Old 08-23-2006, 11:52 AM   #27
schmeep's Avatar
lol, how about an illustrated photo? i couldn't get a decent photo, my camera is crud and there is very little space under uncle yaris's hood.
the yellow blobs represent the two grills on the front, the green lines represent the radiator, and the pink lines represent the block around the radiator
it isn't flush with the grill, so there is probably 6 inches of space in front of the radiator/block that tapers up to the top of the radiator.
Old 08-23-2006, 12:00 PM   #28
You start blocking the grill in the summer time and you will loose AC and the fan will run a lot more and you will end up overheating the engine. It usually runs around 182-186 F with traffic and the fan kick in at 195-205 F - you get less engine wear at the lower temperature according to Miro at Synlube - I asked if higher temp is better and he said that they richen the mixture to help cool the engine when it gets too hot - plus the fan draws a lot of battery power when it kicks in. I would leave it alone until you get it broken in more and the temps gets cooler - winter time is when you really need it to make more heat for the cabin heater. You would think they could color match the hubcaps a little better for the car - that's why I painted mine white.
Old 08-23-2006, 12:03 PM   #29
better mpg
Ya gotta back off on the gas way sooner before you start hitting the brakes - every time you use brakes you throw away gas.
Old 08-23-2006, 12:07 PM   #30
schmeep's Avatar
i've started to do that now, so we will see if any improvement results, thanks for the tip.
Toyota Grand Prius krousdb Automotive News, Articles and Products 5 07-26-2006 03:44 PM
Tuft testing MetroMPG Aerodynamics 5 07-26-2006 03:15 PM
Honda TPS sensor, Turbo manifolds, p75 ECU, pm6 ECU, rare audio console Matt Timion For Sale 6 03-31-2006 08:24 PM
NOS Idea. Capcom General Fuel Topics 16 12-09-2005 05:28 PM
Allview Safety mirror to help eliminate side mirrors? Matt Timion General Fuel Topics 3 09-26-2005 05:12 PM
