1995 CX baltimore - Fuelly Forums
Old 01-22-2008, 12:23 PM   #1
1995 CX baltimore
hey whats up, new here. Just bought a 1995 civic cx and was happy with th mpg but not after i visited here. I usually avg about 29 city and about 36 highway. I know its not running at 100% so hopefully with some minor work and a few tips i saw on here i can get better mpg
DC5_Angelo is offline   Reply With Quote
Old 01-22-2008, 05:57 PM   #2
101mpg's Avatar
There have been a couple recent threads on this exact issue. New plugs, tuneup, and several other items should be checked. Keep us updated - you will get a LOT of input on this.
Old 01-23-2008, 02:54 AM   #3
Welcome! You should be able to get mid 40's with the cx reliably, if it is in good shape mechanically. Does it have the stock tranny and engine? What size tires? PSI? Do you keep the engine at low RPMs and Drive under 65MPH? How many miles does the CX have?
GasSavers_James is offline   Reply With Quote
Old 01-25-2008, 02:21 PM   #4
it has the stock motor and tranny, but it does have 265k on it, the motor is in decent shape. The only thing is the throwout bearing needs to be replaced cause the noise is just killing me. i got 185/65/14 on it, just checked the psi and the front were at 29 psi and the rear were around 24. i raised them all and put them about 40 psi.
Old 01-25-2008, 03:59 PM   #5
smccall's Avatar
Welcome to the site.
Old 01-25-2008, 04:52 PM   #6
Danronian's Avatar
Sounds like the car just needs a tune-up. (plugs, wires, dist. cap, rotor)
Might want to change the o2 sensor while you're at it since with those miles, it's probably due.
partial fuel up... pbfoot Fuelly Web Support and Community News 6 12-29-2013 11:54 PM
Things To Look For When Buying A Civic Vx??? panamacolin General Fuel Topics 10 08-15-2008 04:57 PM
Show Your Sign! Rick Rae General Discussion (Off-Topic) 16 09-25-2007 07:56 PM
Hi everyone, the door was open... metrocruzer Introduce Yourself - New member Welcome 4 09-21-2006 06:13 AM
