Fuelly Android app not working - Fuelly Forums
Old 07-28-2014, 09:05 AM   #1
Using A Motorola Razr Maxx, When I Enter The Mileage, Gallons Used, Or Gallon Price,Then Press "Add Fuel-up", It Brings Me Back Up To One of Those Fields LikE I Left It Blank.
I Have To Click On "View Full Site" And Add The Fuel-Up That Way, Which Takes A Lot Longer
Inybody Else Have This Issue And How Do I Fix It?
GP9195DD is offline   Reply With Quote
Old 07-28-2014, 09:08 AM   #2
RobertV's Avatar
Quite a few posts with users using that same device reporting the issue.
We're looking to release an update here soon that should address the problem.
However, in the meantime, are you able to use the phone's stock browser, and go directly to m.fuelly.com? This is the URL to Fuelly Mobile which that app is just a quick launcher for.
Try to go directly from the browser versus using the app (for now). Let me know if you continue to have trouble.
Old 07-28-2014, 09:14 AM   #3
For some reason, going to that url worked just fine.
I put in a fuel up, then deleted it, no problems
Old 07-28-2014, 09:37 AM   #4
RobertV's Avatar
We know the reason.
The app uses a web-view and doesn't follow the same rules as a web browser.
We're trying to address this and should have a fix soon.
In the meantime, you can bookmark m.fuelly.com and add the shortcut to your desktop for ease of access.
Old 07-31-2014, 03:16 AM   #5
Country: Australia
guys, i have an android phone, a Huawei Ascend Y511 with the fuelly app installed. first time i have used the app to i might add. when i did the fuel up it picked todays date as being back in the 1970's and i had to key in todays date manually. no big deal, got it sorted out easy enough, but if it is possible to make it automagically pick up todays date by default, that would be awesome.
thanks
amazing is offline   Reply With Quote
Old 08-04-2014, 07:51 PM   #6
RobertV's Avatar
thanks
It shouldn't be autofilling with a date from the 70's. Please try going directly to our mobile site at: m.fuelly.com and seeing if the date issue happens again.
