Originally Posted by Andy_Jeff
Sorry, should have said, GC 2.7 - paid version, iOS 8.0.0. Set as you say I can get the 'calculator panel' but the 'picker' that used to be there is no longer working. Also it no longer substitutes in the previous milage to start with if you see what I mean (I'm sure it used to do that). Still intermitting crashes when going into edit previous fillups. This was spotted as I couldn't get any MPG calculations to work since the 2.6 version and had to go back and edit numerous entries. In the end I had to delete anything since 2.6 and re-create, but still get crashes when going to edit, not the first time, but typically when more than one entry needs editing.
Ta.
I've forwarded your post to our developer. Thanks for the feedback!
Originally Posted by boyaviator
Argh! All my data appears to be corrupted after installing the updates.
All cost/L and the L filled are wrong up to June 2014. What did your math engine do?
How do I recover the original data
The default unit setting in Gas Cubby is MPG (US), which means it takes miles and US gallons for input and then outputs miles per gallon. You likely have been using Gas Cubby with other units but, when your data was lost, the units were reset to the default MPG (US). Online Sync only stores the numbers, not the units, so the proper numbers were downloaded but you changed the units back to the proper units setting after the data was recovered, doing a unit conversion in the process.
To fix this, do the following:
Note: if you have not tapped Sync since recovering the data and changing the units, you may skip to step 4.
1. change the units back to MPG (US)
2. go to the Setup/Login screen and tap Delete Synced Data
3. return to the main screen and tap Sync
4. return to the Setup/Login screen and tap Delete Local Data
5. change the units to what you had been using all along
6. return to the main screen and tap Sync.
All your data should now be properly restored.
I would recommend emailing yourself a copy of your fill-up data prior to deleting the Sync data-
http://www.fuelly.com/gascubby/suppo.../gcexport.html
