Issue Refreshing Old Data - Fuelly Forums
Old 06-01-2017, 09:46 AM   #1
My emails to support@fuelly.com are being returned as "undeliverable" so I'm thankful to have found this forum. Ive been a user since the original GasCubby was first released. Loved it then and love this new version also, but do have an on-going issue that I need help with. This seems to have been a problem for the last several versions. I'm currently on version 3.1.8
It seems like two to three times a year my highest MPG will change and be way off my avg. When I scroll down and find the offending gas entry, I can fix it by simply putting it in edit mode, then save it without changing any of the data in the entry - no problem takes a few seconds. It becomes a issue because I must do the same for every single entry after it to present time!
First time it happened I dismissed it as a bug that would be fixed. Second time I deleted and reinstalled the app. Now, today its happened for about the 5th time and I realize something must be wrong with the app. I feel a way to refresh/recalculate all the entries in the app would solve this, is there a way to do that? ...if not is there another way to fix this issue?
UncleJerm76 is offline   Reply With Quote
Old 06-02-2017, 04:03 AM   #2
Site Team
I have not seen this issue before. Therefore, we haven't been looking for a bug to fix.
Do you have the dates/vehicles that this happened on?
The emails from 3.1.8 should be going to Support@Fuelly.com.
I suggest that you verify that your data has synced to Fuelly, then delete and re-install the app. Login by clicking "Set Up Sync" and the data will sync from Fuelly to your iPhone, this will hopefully clear the issue that has affected your data.
Tags
average, mpg, recalculate, refresh, wrong
