Import ACar Data Into Gas Cubby - Fuelly Forums
Old 10-08-2015, 07:31 PM   #1
Is there anyway to import Acar data into Gas Buddy? I'm a pro user on both. I don't mind exporting to CSV and then importing if that works.
therza2169 is offline   Reply With Quote
Old 10-08-2015, 09:21 PM   #2
RobertV's Avatar
Gas Cubby does not currently have an import function.
If you can hang tight a little longer, both will have sync to Fuelly which will achieve your intended result.
Old 10-09-2015, 08:53 AM   #3
Do you have an ETA on that? I'm mainly just worried about my service records as my Android decided to self erase itself yesterday and wipe out all my fill up date since June .
Old 10-09-2015, 11:55 AM   #4
RobertV's Avatar
I hoping just a couple of months. Right now we're laser focused on getting Gas Cubby (iOS) ready to launch with sync to Fuelly. After that is release we can focus our attention on pushing out aCar's beta release.
Old 10-15-2015, 07:23 PM   #5
Robert, I have taken the SQL Lite database and modified it using one of my backups from when I switched from Gas Cubby to ACar a while back. Everything came across great except for the dates. From the looks of it you are using a base date and adding minutes to it to get the float value for the date field. Can you let me know what your base date is, and if you have the formula to covert it that would be even better. Sorry for the odd request lol.
Old 10-15-2015, 08:51 PM   #6
RobertV's Avatar
From what I've read/been told-
"Apple documentation states that iOS data/time values are stored as a time value relative to an absolute reference date-the first instant of 1 January 2001."
Timestamp column in iOS SQLite database | Remko Weijnen's Blog (Remko's Blog)
As for a specific formula... that's above my understanding... so I'll have to get back to you on that.
Old 10-16-2015, 11:50 AM   #7
Thank you Robert for that. I checked it, and you guys are using 1/1/1970 for the base date, and adding the seconds since then. I will modify the tables again tonight. Thanks!
Old 12-18-2015, 06:56 AM   #8
I am in the same boat, prior ACAR user with lots of data history, switched to iOS/Gas Cubby and would like to get the Data Over!
KenRudd is offline   Reply With Quote
Old 12-18-2015, 07:18 AM   #9
If you can pull a backup of the SQLLITE database from Gas Cubby, and have an export from aCar you can marry the data together, just takes some trial and error.
Old 01-11-2016, 02:05 PM   #10
can you elaborate a little more on this process?
jodfie is offline   Reply With Quote
