Gas Cubby Data Recovery... - Fuelly Forums
Old 08-05-2014, 07:19 AM   #1
One day I opened my Gas Cubby and it was asking to be setup. Everything was gone.
When I restore the files from the backup, it crashes when it runs.
Is there a way to get the data out of the database? I had a lot of entries I do not want to loose.
I checked the sync setting and I guess I never set that up properly, so I only have the files from the com.appcubby.gascubbyfram directory.
Any help would be appreciated.
RacerBear is offline   Reply With Quote
Old 08-05-2014, 05:35 PM   #2
RobertV's Avatar
I don't have an answer for you yet, but give me a couple of days to research one for you.
Thanks for your patience!
Old 08-06-2014, 09:56 AM   #3
Thank you very much!
Old 08-08-2014, 07:18 PM   #4
Well? Have you learned anything?
Old 08-08-2014, 11:13 PM   #5
RobertV's Avatar
No update yet. We're still looking into it though!
To clarify, you've never set up sync, so all your data was stored locally on your device and then it just randomly was wiped?
Old 08-09-2014, 12:38 PM   #6
The data was stored on the device and I did an update and then it was acting empty. So I went to the backup pre the update and retrived that directory.
Old 08-15-2014, 10:39 AM   #7
SO nothing? I'm just SOL?
Old 08-18-2014, 06:18 AM   #8
RobertV's Avatar
RacerBear,
Josh (member of Fuelly Team) sent you a message on the 15th and as of this writing hasn't received a response from you.
Posting here just in case the message was buried in your inbox, and you see this first!
Thanks!
Old 08-21-2014, 06:47 AM   #9
I got it in the PM here, however, he was just asking me if I setup the sync, and did not respond to all the information I have provided on here. I reiterated it and provided details of the files I have in the backup.
Old 08-25-2014, 10:25 AM   #10
No response from Josh to my Private Message...
