Gas Cubby 3.1.9 - Fuelly Forums
Old 05-31-2017, 06:40 AM   #1
Gas Cubby 3.1.9
Updated to latest v3.1.9 last night and my IOS mobile app won't run and crashes every time. This is the first problem I've had with this app; even the recent conversion went trouble-free. Please fix soon! I love and depend on Gas Cubby!
BlastermanTX is offline   Reply With Quote
Old 05-31-2017, 08:26 AM   #2
Me too. Same issue.
BBBilly is offline   Reply With Quote
Old 05-31-2017, 11:38 AM   #3
Country: Greece
Me too same issue.
electroasd is offline   Reply With Quote
Old 06-01-2017, 05:32 AM   #4
Updated to Gas Cubby 3.1.9
I updated to Gas Cubby 3.1.9 yesterday and cannot get into the application since that version was updated. Hope that there is a solution very soon as I use this app almost every day to track stuff on my vehicles.
jkreutz1952 is offline   Reply With Quote
Old 06-01-2017, 09:19 AM   #5
Site Team
Please verify that your data has synced to your Fuelly profiles. If yes, then delete Gas Cubby and re-install from the app store. Login by clicking "Set Up Sync" and the data will sync from Fuelly back to your iPhone.
This will correct the crashing/failure to open issue.
Old 06-01-2017, 10:59 AM   #6
I just used this workaround with success.
I logged onto the Fuelly site to make sure my most recent activity was reflected on the website. Then I deleted the app on all devices, re-installed the app from the store and re-synced the data. Worked fine.
landcruisers is offline   Reply With Quote
Old 06-01-2017, 11:17 AM   #7
Site Team
I'm glad to see that you're able to post.
The delete and re-install works. I also do the app testing, the problems reported never occurred because I always delete & re-install between the tests.
The developers are currently digging into this.
Old 06-01-2017, 11:48 AM   #8
I was able to use this process and it worked fine. The only issue that I am seeing now is that the system is working very slowly. I am Syncing All Data now and will try it again after completion. I will check back tomorrow to see about the slowness in performance.
Old 06-05-2017, 10:49 AM   #9
I did not have this issue until 3.1.11
KStateFan is offline   Reply With Quote
Old 06-06-2017, 08:22 AM   #10
Site Team
I'll notify the developers.
