who's using OBD with a laptop? - Page 3 - Fuelly Forums
Old 01-24-2006, 02:01 PM   #21
If anyone has any experience
If anyone has any experience with mass airflow meters disco recommended using that and afrs to figure it out, also. Just something to throw out there.
Old 01-24-2006, 05:41 PM   #22
you're right, flatland - the
you're right, flatland - the scangauge doesn't measure actual flow, it's a calculation based on pulse width, air flow, displacement and other factors. that said, it's been pretty darn accurate for me (within 2% of "manual" calculations on the gas receipt at fill-up time).
Old 01-24-2006, 07:15 PM   #23
Re: Question - when I get my
Originally Posted by DaX
A short thing would be tesing whether driving at WOT in 5th is better than light throttle [is reducing pumping losses outweighed by a larger injector pulsewidth?].
Things like this I really can't wait to test out.
I think Hondas since the beginning of time are open-loop at full-throttle. I'd like to know this too as I drive my TL with the auto-stick, get into 4th as soon as I can, and mash the gas.
Old 02-15-2006, 04:47 PM   #24
FYI... been watching eBay
FYI... been watching eBay for about 3 weeks now for a used laptop-connectable OBD2 unit for proper data-logging ability.
kicked myself on friday because i missed out on a real deal: it went for $50 - and the only reason i missed it is because of a web/browser glitch at the crucial bidding moment (15 sec before the auction ended).
i don't really want 2 separate units. the scangauge is so convenient since it's self-contained, no muss, no fuss. i think i posted this elsewhere here, but i did write to the company to see if they would ever consider adding a USB/serial output, and they basically said no.
how hard would it be to add one? opinions of any electronics experts??
Old 02-15-2006, 06:01 PM   #25
Depends on the internal structure of the thing. OBD0 and OBD1 honda ecus it's as simple to do as adding a 25 dollar cable from radioshack because it's already set up with communications ports.
Prolly *** hard on the scanguage I'd guess though.
Old 02-15-2006, 09:34 PM   #26
Matt Timion's Avatar
Re: Quote:how hard would it be
Wait, I thought you said it has to be chipped first to send the data? Which is it? Can I just hook up the cable to my obd1 ECU and get data from there?
Old 02-16-2006, 04:02 AM   #27
It does have to be chipped
It does have to be chipped to send data, I was just museing on the fact that the communication port architecture, or lack thereof, is probably the biggest hassle when doing this.
The ecus have the communications port so it is just a matter of plugging in, whereas metro might have to create one (if that's possible) to even be able to access data.
Old 02-16-2006, 09:36 AM   #28
Moderator
GasSavers_DaX's Avatar
I think it's time to post
I think it's time to post pictures of PCB's!!!!!
Old 02-16-2006, 10:29 AM   #29
you want to see the innards
you want to see the innards of the scangauge?
Old 02-16-2006, 10:34 AM   #30
Moderator
NM...for some reason I
NM...for some reason I thought your ECU was OBD-1...then I wanted to see a shot of its innards.
Partial Fuel Up - Calc Improvement suggestion RadarKen Fuelly Web Support and Community News 1 11-23-2011 07:17 AM
Expand the data stored dkidwell Fuelly Web Support and Community News 2 10-29-2008 07:52 AM
allow sign-in with user name funkd00bi3st Fuelly Web Support and Community News 1 08-11-2008 01:23 PM
Honda n600 on the east coast (Virginia) - $750 Matt Timion For Sale 1 06-19-2006 04:34 AM
Car, Van, and Light Truck Disc Brakes and Fuel Economy Matt Timion Automotive News, Articles and Products 0 10-03-2005 01:17 PM
