What do you monitor with your ScanGauge? - Page 3 - Fuelly Forums
Old 09-03-2007, 03:33 PM   #21
Originally Posted by ZugyNA View Post
Is LOD calculated by dividing TPS by RPM?
I'm pretty sure I've had load increases on hills with no Δ in TPS.
Old 09-04-2007, 07:35 AM   #22
ZugyNA's Avatar
But your rpm went down? So LOD went up?
Old 09-04-2007, 07:56 AM   #23
ZugyNA, the joys of drive-by-wire gas pedals. My foot determines the TPS number, the ECU determines the LOD.
Old 09-05-2007, 04:41 AM   #24
ZugyNA's Avatar
I'd bet (but not too much) that if you set up TPS/RPM/LOD on your scangauge...you'd see the calculation in realtime.
As RPM goes up at same TPS...LOD goes down? As TPS goes up at same RPM...LOD goes up?
Add in MPG and you should see an almost direct inverse relationship with LOD?
Mothballs / Napthalene / WD40 SVOboy General Fuel Topics 24 11-12-2007 08:17 PM
Belated Intro GasSavers_brick Introduce Yourself - New member Welcome 4 12-22-2006 06:48 AM
Vote now for your favorite signature image! Matt Timion General Discussion (Off-Topic) 17 09-28-2006 09:42 PM
Who drives a 1/reduced seater? SVOboy General Fuel Topics 9 05-16-2006 06:28 PM
Atlanta Auto Show GasSavers_DaX General Discussion (Off-Topic) 26 05-07-2006 05:02 PM
