 minic6 Gauge 07-16-2007, 05:21 PM
07-17-2007, 02:57 PM
Originally Posted by Mentalic
Using the Scangauge for feed back I can tell that my 4 Runner does not cut the fuel in engine on coasting at all. Going down hill at 60mph in gear the fuel burn is .5-.6 gph, flip in neutral its .3-.4 gph at 60mph. The instant FE numbers take a jump higher when I flip in neutral as well. So for me its far better to coast in neutral.
Which is an excellent example of why to use a Scangauge.
Far better than gut instinct, other gauge types, pretty much anything else, if you want improved FE.
Requires OBDII which started in '96 so not workable for older cars like mine...
07-18-2007, 10:55 AM
Originally Posted by Rick Rae
Another approach I've played with a few times is to leave it in "D" and try to find the "Goldilocks zone" with the accelerator. By that I mean: If you just take your foot off the gas in gear, you start engine braking. If you leave your foot locked in place, your MPG value goes up somewhat because the load is reduced thanks to the downslope. Somewhere in between, there's a point where you're feeding just enough gas to rev-match the engine to how fast the road wants to turn the tranny. So you're not engine braking, but neither are you putting any load on the engine. If you tracked it perfectly you'd get the same glide distance as you would in neutral. Again it would come down to a similar question: Do you gain more running the engine at higher RPMs but with zero load over a long distance or in idle over a much shorter distance?
Maybe I misunderstand what you are saying here but I can't see how this approach could be as good as coasting in neutral (at least for FE, safety is another question). I think what you are describing is giving the engine just enough gas to overcome the effect of engine braking so that your speed at any point on the hill will be equivalent to what it would be if you were coasting in neutral. I think that the amount of gas required to do this would be the same as what would be required to rev the engine to the appropriate rpm in neutral (i.e. there is no load on the engine except its own friction, and the power required to pump air, and whatever other losses are involved). Therefore you would burn the same amount of gas by this approach as coasting down the hill in neutral with the engine revved to the higher rpm and I don't think that would produce better FE then just coasting in neutral. I would actually like to be wrong about this because I would rather coast in gear then in neutral if the FE is the same.
07-18-2007, 11:50 AM
Originally Posted by viper75
... I think what you are describing is giving the engine just enough gas to overcome the effect of engine braking so that your speed at any point on the hill will be equivalent to what it would be if you were coasting in neutral. I think that the amount of gas required to do this would be the same as what would be required to rev the engine to the appropriate rpm in neutral... Therefore you would burn the same amount of gas by this approach as coasting down the hill in neutral with the engine revved to the higher rpm ...
I think there's a significant difference between the fuel needed to overcome engine braking and the fuel needed to rev the engine to speed in neutral - because if you're going to coast in gear you'd be providing that fuel continuously during the coast - assuming you could find the exact correct pedal position to accomplish it. If you're coasting in neutral and need to spin the engine up before going back in gear you only need to do it once at the end of the coast. A huge difference, as long as you're coasting more than ten feet.
If a driver just doesn't find sufficient control with the engine in neutral I won't disagree with their own perception. However I think it would be difficult or impossible to show that you can coast in gear as well as you can coast in neutral. With or without fuel or wind or anything else. If you're in gear then the car's momentum is being used to spin the engine. If spinning the engine is of value to the driver then OK. But let's not fool ourselves into thinking it's going to get you as far on the same fuel compared with coasting in neutral.
If you want to improve on that, you cut the engine off, or install a fuel cut button. I rarely cut the engine on my auto trans car but I know that some standard drivers do it. You can bump start a stick shift car pretty quickly so it's not quite the same as with an auto.
07-18-2007, 04:38 PM
I wasn't saying you bump the throttle once at the end of the coast to match revs so you can put the car in gear. I was saying you would burn the same amount of gas if you kept the rpms higher the entire way down the hill with the car in neutral as you would coasting in gear and giving the car light throttle the way Rick was describing. It doesn't matter though because Rick wasn't saying that he could match the efficiency of coasting in neutral by coasting in gear with light throttle which was my initial interpretation of his post. And we all agree it would be impossible to get the throttle position exactly correct anyway but I'm curious to see what his testing turns up.
07-18-2007, 02:49 PM
...I think it would be difficult or impossible to show that you can coast in gear as well as you can coast in neutral.
You could safely drop the "difficult or" in a vehicle without fuel cutoff (as mine appears to be).
...let's not fool ourselves into thinking it's going to get you as far on the same fuel compared with coasting in neutral.
If someone suggested that, I missed it. I certainly don't think that's the case. You guys with stick shifts have it all over us automatics in that regard (as well as others).
You didn't misunderstand, you merely overlooked.
FE-wise, I absolutely agree that coasting in gear can't match NICE-ON coasting... which in turn pales in comparison to EOC. The bit you might have overlooked is this:
Originally Posted by me
I wouldn't even bother with that, but A) I've yet to see evidence that my car does fuel cutoff, and B) throwing my automatic in and out of neutral at highway speeds makes me uneasy (when I think about it ).
I can't safely EOC with my automatic. I've watched my transmission temperature climb unnervingly high during NICE-ON experiments, I sometimes think I hear disturbing sounds bouncing off of reflective surfaces when I drop it back in "D," and I don't have a definitive answer to whether NICE-ON coasting is safe for my vehicle. And my engine doesn't appear to cut fuel during in-gear idle coasts, so I can't trade off zero fuel use against engine braking.
That leaves trying to feather the accelerator into the "Goldilocks region" as one other option to explore, which is all I'm doing: exploring. I'm not offering it as a recommended or even useful technique at this point; I'm too new to all of this... crawl before you walk, and all that.  I just gave it as another example of where you'd have to weigh this against that to determine which approach was better for a given situation (vehicle, driver, traffic, etc.) Apologies if I muddied the waters by mentioning it at that point.
Correct.
...you would burn the same amount of gas by this approach as coasting down the hill in neutral with the engine revved to the higher rpm...
Seems about right. The other effects are that A) you'll glide farther than you would if you took your foot off the gas and subjected yourself to engine breaking, and B) you'll use less gas than if you keep the throttle locked. Where's the sweet spot? Dunno, but playing around with it is one way to find out.
I don't think you're wrong. No way would you come up with the same numbers. I doubt you could even get close and that's assuming perfect control of the gas, which brucepick and I both implied would be nigh onto impossible.
If I can get half the efficiency of a NICE-ON glide I'll be pleasantly surprised. As you both said, I'm giving the engine fuel to keep it at speed the whole time, after all (even if it is unloaded, assuming a perfect rev match).
If a driver just doesn't find sufficient control with the engine in neutral I won't disagree with their own perception... If spinning the engine is of value to the driver then OK.
For the record, I don't have that perception, and the value to this driver is not destroying either of my transmission or my nerves.
Honestly, I want to NICE-ON coast (heck, I want to EOC glide!). I've been playing with it; I love the velvety feel, I love the MPG numbers. But until I feel confident it doesn't put excessive stress on my transmission or TC, I'm not going to push it. In the meantime, I'm playing with whatever other techniques I can think of to see how close I can get to the same fuel efficiency. Maybe I'll settle on coasting in neutral at low speeds and something else on the highway; who knows at this point. Like I said, I'm new.
I hope that clarifies things a bit?
Rick
07-18-2007, 03:21 PM
(cant EOC cuz automatic
FYI, I did an auto to manual swap on an older VW, used a $300 parts car for all the bits. It wasn't too bad. Only ***** was those funky axle bolts. I'm sure folks have done it on your year and sorted out the computer crap. Sure, not everyone can, but if you can then definately consider it.
http://www.vwgolf-mk2.com/eatmtconversion.html
07-19-2007, 10:23 AM
I can't safely EOC with my automatic. I've watched my transmission temperature climb unnervingly high during NICE-ON experiments, I sometimes think I hear disturbing sounds bouncing off of reflective surfaces when I drop it back in "D," and I don't have a definitive answer to whether NICE-ON coasting is safe for my vehicle. And my engine doesn't appear to cut fuel during in-gear idle coasts, so I can't trade off zero fuel use against engine braking. Rick
YIPE! I wouldn't ever do that again. An automatic's fluid pump is driven off the input shaft from the engine. When coasting with the engine off, fluid is not being pumped which means various bearing inside the trans are not being lubed. When they aren't being lubed, they are running metal on metal, and burning off. That is what is causing your high temps, and is greatly increased your tranny wear. It is such a problem that if a tow truck tows an automatic 20 miles on the drive wheels with the engine off, that transmission is toast. Tow truck drivers that are pulling RWD cars will either tow them backwards, or disconnect the driveshaft before towing.
07-17-2007, 04:56 AM
The more automated things are, the harder it is to get them to do what you want
07-18-2007, 02:10 AM
I don't want to spend the $$$ on a SG. I think my car does fuel cutoff.
Can any other Saturn owners here confirm that s-cars do fuel cutoff? Even if they do cutoff, it seems to me like the glide goes MUCH further out of gear than in gear.
In any event, I've changed my commuting route over the past couple days to one that seems to avoid long waits at left turns. Yay!
However, my MPG may suffer for a little while yet -- I changed my battery a couple weeks ago, and I think in so doing wiped out the computer's FE knowledge.
Team: Right Lane Rollers
07-18-2007, 04:14 AM
Rather spend it on the extra gas you're burning from driving blind, eh?
Rick
