Update on Hypermiling in the Prizm - Page 2 - Fuelly Forums
Old 10-18-2011, 01:39 PM   #11
Re: Update on Hypermiling in the Prizm
With an automatic it might be better getting up to the high gear quickly. Lingering in the lower gears can burn more fuel.
Old 10-18-2011, 03:00 PM   #12
Did you read what the OP posted? Stop and go traffic all the way so ergo, no way to get into high gear.
1cheap1 is offline   Reply With Quote
Old 10-19-2011, 08:34 AM   #13
Even then, slower acceleration might might still be of lower benefit than a micro pulse and coasting. Maybe try a lower gear. I've heard economy increases with a lower gear while in traffic with some models. DFCO might also become more aggressive.
Old 10-27-2011, 08:52 AM   #14
brucepick's Avatar
With an automatic, decisions based on rpms can be odd. I've seen rpms go up and speed stay nearly the same because it's not a direct gear drive; it's a turbine type drive and there's lag. They only go into lockup once you get to cruising state.
Back to the gas log issue -
You could start a new "vehicle" for this six month period. Track your mpg there until the bridge gets reopened. That way, if you get brilliant and find a way to improve the results, it will show up as an improvement over the earlier weeks commuting over messed up roads.
Old 10-27-2011, 01:25 PM   #15
I go by TPS or load on the scangauge. 70% load is where most engines are at their most efficient for accelerating.
Old 10-28-2011, 07:14 PM   #16
theclencher's Avatar
Gas log games... who are you trying to impress? It's supposed to be a factual record fer chrissakes.
Tempo/Topaz:
Old EPA 23/33/27
New EPA 21/30/24
F150:
New EPA12/14/17
Old 10-30-2011, 06:03 AM   #17
Just post it in your notes that theres road construction. it's all about doing the best you can under the circumstances. Otherwise people would just not post there winter numbers and just wait till summer so they can just post good numbers.
Old 11-01-2011, 09:11 AM   #18
goofy1's Avatar
Well I went ahead and update my gaslogs. I couldn't find a one of my recipts. but it wasn't a full tank fill, i only put 2 gallons in it to make it home before a vacation. I read the advice from everyone and decided to by accurate with the fills. Sorry about that.
"But Doc, we dont' have enough road to get it up to 88 miles per hour"
goofy1 is offline   Reply With Quote
Old 11-01-2011, 10:44 AM   #19
200,000 a big deal (for me anyway) GasSavers_BEEF General Discussion (Off-Topic) 40 02-03-2012 03:45 PM
Mitsubishi L200 S T O R M V6 consumption increase 2drive General Fuel Topics 3 06-03-2011 03:30 AM
shopping for o2 sensor 1993CivicVX General Maintenance and Repair 2 10-27-2008 02:04 PM
Check engine light code 48 92VXHatchguy General Fuel Topics 6 05-20-2008 03:49 PM
VX tailgate and other parts 1993CivicVX For Sale 0 09-24-2007 07:11 PM
