Ultra-Gauge beats ScanGauge at ~1/3 the price - Page 2 - Fuelly Forums
Old 08-26-2010, 09:19 PM   #11
FrugalFloyd's Avatar
Re: Ultra-Gauge beats ScanGauge at ~1/3 the price
Yes, it measures EOC properly. There's no fuel consumed, and the miles keep being counted. At the end of my 9.6 mile test loop, P&G mpg results are the same with the UG as they are with the SG. Distance results are the same, too, with only 9.3 miles measured. The UG loses miles duing the key-off time, just like the SG.
Old 08-27-2010, 01:30 AM   #12
Does the ultra gauge cover more protocols than the scanguage?
Old 08-27-2010, 02:29 AM   #13
Member
I'd also like to know if it can communicate with JDM cars' ECUs, specifically Toyota J-OBD as I think it's called.
Shame there isn't a metric option though.
markweatherill is offline   Reply With Quote
Old 08-27-2010, 08:29 PM   #14
Is there anyplace other than Ultra-gauge.com that sells these?
PhotoDu.de is offline   Reply With Quote
Old 08-28-2010, 12:21 AM   #15
AFAIK, they both cover the same protocols - all the variants of OBDII communications - KWP2000, 11 bit CAN, CANSF, etc.
They're both designed to gather and display OBDII data, so unless that Japanese standard shares some OBDII items, I can't imagine the UG working with the Japanese standard.
The Ultragauge FAQ says you can only buy the UG from the linked website.
Old 08-29-2010, 06:58 PM   #16
I took delivery of my Ultragauge Saturday. so far it apears to do exactly the same stuff the Scangauge did but at a price that is much more palatable to the average consumer. The main things I like are the size (it's tiny) and the display (for it's tiny size the display is huge and well laid out). I have only put a few miles on it and I like it better than the scangauge. The main reason is it blends with the interior better than the scangauge second is it's easier to read.
Old 08-29-2010, 08:39 PM   #17
I mailed in my rebate paperwork today, and noted that exceeding 170 degrees internal temperature on the UG voids the warranty. When I left it in my xB's window on a 100 degree day, the internal temp went up to at least 173 degrees, so be forewarned. Rather than unplug the UG, I remove it from its mounting stalk, and stow it out of sight under the dash and out of the sun, now. It looks a lot like a small GPS, so you wouldn't want to leave it in plain sight anyway. Someone is sure to break your window and try to steal it.
Clarification on the introductory $39.95 price. I should have said that's plus ~$8 shipping, and after a $9 rebate. So I was billed about $56, and will pay about $47. Now that regular pricing applies, an UltraGauge will cost about $68 - about $100 less than a ScanGauge.
Old 09-01-2010, 10:39 AM   #18
This may be a dumb question, but I'm just getting started here. Bought a 94 Civic VX a few weeks ago. Does the UG only work on OBDII cars? What about the SG?
Also, are you getting that 46mpg average simply through driving habits, or have you done any mods to your Scion?
mcc6 is offline   Reply With Quote
Old 09-01-2010, 10:46 AM   #19
GasSavers_BEEF's Avatar
both scangauge and ultra gauge are obd2 only.
there is the mpguino that you can use on older cars though I know very little about it since I have obd2. several people have used it and it seems to be fairly nicely done but I think it is a kit you have to build yourslef.
Old 09-02-2010, 10:55 PM   #20
BamZipPow's Avatar
Send a message via AIM to BamZipPow
Just pulled the trigger on one...maybe the wife's car will the the SGII now...
BamZipPow is offline   Reply With Quote
epa estimates cseverens Fuelly Web Support and Community News 2 06-09-2010 04:48 AM
MPG rally in Washington is a conditional 'go' bones33 General Fuel Topics 12 05-03-2009 08:13 PM
tire warped because of too much psi kickflipjr General Fuel Topics 30 04-24-2007 01:09 PM
