short shift, how short? - Page 2 - Fuelly Forums
Old 05-23-2007, 08:59 PM   #11
lovemysan's Avatar
I get better in town mileage when shifting at very low rpms.
1-2 700-1000rpms
2-3 1100
3-4 1300
4-5 1500
level ground, downhill slightly less rpm, uphill slightly more rpm. The saturn pulls cleanly off idle in most situations
02 Saturn SL
5 speed
for pics click the link below
[SIGPIC][/SIGPIC]
Old 05-23-2007, 09:13 PM   #12
1-2 700-1000rpms
2-3 1100
3-4 1300
4-5 1500
I guess it really depends on the vehicle! Theres no way I shift into 5th at 1500 rpms, no way. In 5th at 1500, it has a hard time accelerating on flat ground at all. But it is a jap car. they are more upper rpm HP, and not mucch bottom end. Its gutless below 2000 in any gear. Prefers 3000+. I will have to try a tank shifting at 3000, instead of my now usual 2500.
Old 05-23-2007, 09:27 PM   #13
Hey, byobbq, say something intelligent about what this graph says about where to shift.
To me it seems to say that you would want to be asking for nearly the maximum torque, and shifting at about 2600 rpm, trying to keep the revs and the torque demand right on that region of the best BSFC.
Old 05-24-2007, 12:31 AM   #14
Team GasMisers5!
landspeed's Avatar
However the 'previous engine' had the most efficient areas not so tightly concentrated.
On my car with SuperMID, I have found that keeping the revs low does help fuel economy - seeming a lot more important than most other things!
And it is a 1.8 japanese engine!
Hypomiler
Old 05-24-2007, 11:55 AM   #15
rvanengen's Avatar
Originally Posted by Bill in Houston View Post
<snip>To me it seems to say that you would want to be asking for nearly the maximum torque, and shifting at about 2600 rpm, trying to keep the revs and the torque demand right on that region of the best BSFC.
Bill...does that mean I would be better keeping my car near it's torque peak...or just keeping it at the lowest % throttle that I can?
-- Randall
McIntyre's First Law: "Under the right circumstances, anything I tell you may be wrong."
O'Brien's First Corollary to McIntyre's First Law: "I don't know what the right circumstances are, either."
rvanengen is offline   Reply With Quote
Old 05-24-2007, 12:34 PM   #16
From the graph, it looks like you want to be pretty close to the peak, meaning stepping on it pretty hard... Still hoping for BBQ (or someone else) to confirm my understanding of the graph...
Old 05-24-2007, 12:39 PM   #17
rvanengen's Avatar
What kinda toyota do you have that motor in?
Do you know if you can find that kinda graph for a Mercedes 103.940 motor, or did you get this from a dyno?
-- Randall
Old 05-24-2007, 01:36 PM   #18
Ya, exactly. BYOBBQ posted it. He has (or had) a Camry. I have not been able to find one for the K24 engine in my car. It seems to me that if the engine in every Accord, Element, RSX and TSX for the last 5 years doesn't have a BSFC chart that is findable on the internet, finding one for the Mer will be difficult...
Old 05-24-2007, 02:31 PM   #19
minic6's Avatar
Remember your gear ratios will make the biggest change between cars. A 3.5 versus a 4.1 will have to spread the shifts out further to get the same results. Also your trans ratios have much to do with it. I can right now be in 3rd gear in about 3 car lengths of the geo, it will be interesting to see what will change when the 14s are installed. Experiment and see it's the only real way to see. Japenese or European cars like to rev. american cars usually have lots of torque. Thats why in cars equiped with skip shift under 30&#37; throttle will go 1st to 4th.
minic6 is offline   Reply With Quote
Old 05-24-2007, 08:25 PM   #20
lovemysan's Avatar
My car is pretty gutless all over. Especially in 5th gear. Sometimes I shift and wait for the acceleration to happen. la la la, anyday now! That sort of thing. I tried the short shifting in an altima and it just wasn't compatible. Too much weight and not enough low end torque.
Thing biggest thing that will help you decide which method is a supermid or an SG2.
good luck
02 Saturn SL
5 speed
[SIGPIC][/SIGPIC]
Please add country filter raysky Fuelly Web Support and Community News 1 10-17-2012 02:20 AM
Rounding errors mrtickle Fuelly Web Support and Community News 3 11-18-2010 04:40 AM
Any luck with VW/Audi solar panels? SVOboy General Fuel Topics 0 06-16-2006 02:10 PM
Really interesting read... Compaq888 General Fuel Topics 0 02-07-2006 04:59 AM
What does a coil do? Matt Timion General Maintenance and Repair 5 11-28-2005 08:56 AM
