Scangauge wrongly reports TPS@16? - Fuelly Forums
Old 08-29-2007, 08:16 PM   #1
On a 96 Intrepid, SG is reporting TPS at 16. But the throttle is not depressed and the butterfly is closed...
Whats going on?
-unknown
Old 08-29-2007, 08:23 PM   #2
My Santa Fe is 13 or more idling. It's just a marker number.
Old 08-29-2007, 08:38 PM   #3
Yeah? And I think your Santa Fe is brand new so right on, its just a marker number. No worries then, hmm.
-unknown
Old 08-29-2007, 08:54 PM   #4
My Focus is also 16 at idle. It has to be open a little bit to allow enough air through for the engine to idle. On some cars, this scale starts at zero, but it's never really closed all the way unless it has a separate idle circuit.
'00 Echo - DD
'11 Kia Rio - Wife's DD
Old 08-29-2007, 09:12 PM   #5
trebuchet03's Avatar
2000 2.0 Jetta
a/c off - TPS = 3
a/c on - TPS = 5-6
Max TPS = 75
11/12
Old 08-30-2007, 07:39 AM   #6
Think the Flea's idle TPS is around 13.
Old 08-30-2007, 03:41 PM   #7
GasSavers_Red's Avatar
14-16 is usually the default value on DCXs
Old 08-30-2007, 03:49 PM   #8
ELF
ELF's Avatar
TPS on the sable was at 16. but I changed it to 18, car had more power right off idle and got the same mpg.
Old 08-30-2007, 05:17 PM   #9
Baseline Figures
You need to establish the baseline at zero throttle and full throttle:
Hondas (IIRC) generally are 9-92% TPS (zero = 9, and WOT = 92). Each vehicle's user has to adapt to the similar output numbers.
Old 08-31-2007, 05:23 AM   #10
Yes... and this can be checked engine off.
Graph is not matching DTMAce Fuelly Web Support and Community News 6 10-19-2011 09:56 PM
Mothballs / Napthalene / WD40 SVOboy General Fuel Topics 24 11-12-2007 08:17 PM
Belated Intro GasSavers_brick Introduce Yourself - New member Welcome 4 12-22-2006 06:48 AM
Atlanta Auto Show GasSavers_DaX General Discussion (Off-Topic) 26 05-07-2006 05:02 PM
Found another way to save on gas. Compaq888 General Fuel Topics 42 03-16-2006 04:48 PM
