ScanGauge: What are Your Settings? - Page 2 - Fuelly Forums
Old 04-29-2007, 01:48 AM   #11
Compaq888's Avatar
TPS, MPG, MAP and RPM( I have no tach and don't plan to waste my money on one.)
Old 04-29-2007, 05:06 AM   #12
How's the 5-speed workin' out?
Old 04-29-2007, 09:19 AM   #13
psyshack's Avatar
TPS, MPG, MAP, In Take Air.
Spends most of its time on current trip.
09 HCHII, w/Navi
07 Mazda3 S Touring, 5MT
Mild Hypermiler or Mad Man?
Old 04-29-2007, 02:40 PM   #14
Compaq888's Avatar
great!!! One day it didn't want to go into gears and I had to stuff it in there. Next day I was driving and it was grinding like crazy whenever I tried to shift. Got off the freeway and put it into 1st and it started rolling back, no pedal pressure at all. Had to get it towed. I got the entire clutch system replaced. Only the pedal is original. They also discovered I had a leaky rear main seal when they pulled my tranny so I got lucky and only spent $77 to fix that.
The difference is night and day. The pedal is smooth now and you can feel where the engagement point is. Accelaration onto freeways is so much fun now.
Sorry for blabbing...
Old 04-29-2007, 04:40 PM   #15
WT MPG
IAT MPH
I change the IAT if I want to monitor LOOP, IGN, TPS, or LOD.
usedgeo
usedgeo
Old 04-29-2007, 05:45 PM   #16
°FWT VLT
MPG TPS
Water temp so I can keep an eye on the effects of the grill block and use the heater if necessary to keep it down; voltage to keep an eye on battery drain when coasting with engine off and lights on; MPG to see the effect of what I'm doing and TPS to dial in my optimum throttle positions. Of all of them, I value TPS the most, by far.
I may change VLT to LP or LOD now that winter's over.
GasSavers_Bruce is offline   Reply With Quote
Old 04-29-2007, 05:56 PM   #17
BumblingB's Avatar
MPG MPH
FIA fWT
BumblingB is offline   Reply With Quote
Old 04-30-2007, 04:49 PM   #18
silverinsight's Avatar
Tl=rpm
Tr=*fwt
Bl=vlt
Br=*fiat
silverinsight is offline   Reply With Quote
Mothballs / Napthalene / WD40 SVOboy General Fuel Topics 24 11-12-2007 09:17 PM
Belated Intro GasSavers_brick Introduce Yourself - New member Welcome 4 12-22-2006 07:48 AM
Who drives a 1/reduced seater? SVOboy General Fuel Topics 9 05-16-2006 07:28 PM
Atlanta Auto Show GasSavers_DaX General Discussion (Off-Topic) 26 05-07-2006 06:02 PM
Wiki added Matt Timion Fuelly Web Support and Community News 19 03-29-2006 04:27 PM
