Scangauge questions - Page 2 - Fuelly Forums
Old 06-17-2008, 11:29 AM   #11
No, really mine was never getting past the first quarter mark, so I repaced the thermostat and checked the coolant temp sensor... now it gets between first quarter and halfway... maybe its another coolant temp sensor gone bad... my Saturn (S-Series in general) is known for it.
John
'09 Saturn Aura 2.4L
'96 Chevy C1500 (5.0L 5sp)
'01 KTM Duke 2
Old 06-18-2008, 04:30 AM   #12
GasSavers_BEEF's Avatar
I'd block the grill and see what happens as far as temps. around here we have seen 100 deg days and mine seems to stay pretty firm even though I am running a WAI and have the grill blocked about 80 percent.
Old 06-18-2008, 05:17 AM   #13
I'm working on my HAI and the left over material may be used as a grill block, just depends on how silly I'm feeling this evening when I get back to it.
John
'01 KTM Duke 2
Old 06-20-2008, 03:23 PM   #14
Originally Posted by PaleMelanesian View Post
You're right about the speed calibration. Just re-check it after a whole tank and fine-tune based on the results.
Cutoff is for DFCO. If your car has DFCO, you want to set it to the TPS reading at idle. Verify with the open/closed loop gauge - open loop means you're in DFCO mode. You should see 9999 mpg and open loop at the same time, and lower mpg / closed loop any other time, with the transition between the two aligned. You may have to adjust the cutoff +- 1 to get it dialed in.
Not really, they recommend the idle reading +4 as the default.
OfficeLinebacker is offline   Reply With Quote
dead battery? lunarhighway General Maintenance and Repair 8 12-20-2007 02:07 AM
Mothballs / Napthalene / WD40 SVOboy General Fuel Topics 24 11-12-2007 09:17 PM
Saturn TDI for S-Series cfg83 Diesels 14 10-02-2007 02:24 PM
Anyone have experience making their own solar panels? MetroMPG Electric and Solar powered 17 08-29-2007 06:43 PM
Atlanta Auto Show GasSavers_DaX General Discussion (Off-Topic) 26 05-07-2006 06:02 PM
