ScanGauge II - Page 2 - Fuelly Forums
Old 12-18-2007, 05:47 PM   #11
Originally Posted by Project84 View Post
Not sure I'm following you.
Say you have a misfire in cyl. #3, does it tell you, Misfire: Cylinder 3.
I recently had SES Lights on and had to (once again) make a trip to see a friend w/ an Actron scan tool to find out why the SES came on. Luckily, his tool tells you what is wrong, other than say "P1440". Get what I mean?
It is not very hard to look the codes up on the net or in a book. I have a cheap scantool also that says what the problem is. I was looking at a used 1996 saturn and it was warmed up but the computer was running on 115 F. I thought it was neat to see the common temp sender failure right on the scangauge. I don't know if the scantool would have been any more useful. The car was not setting any codes.
usedgeo
Old 12-18-2007, 06:31 PM   #12
skewbe's Avatar
I don't read enough codes with mine to make looking up the code a big deal. I suppose if I did it for a living I would like a nicer one. The standard verbiage can be misleading, i.e. my saturn returned a code for "camshaft position sensor malfunction", My saturn doesn't HAVE a camshaft position sensor and this seemed an odd time for the computer to start noticing it. A google for the code and my car model led me to the cause of the problem, the ignition coil was going south.
Standard Disclaimer
Old 01-26-2008, 11:29 AM   #13
Originally Posted by caveatipse View Post
Worth it?
Every penny!!!!
yi5hedr3 is offline   Reply With Quote
Old 01-26-2008, 12:06 PM   #14
Originally Posted by yi5hedr3 View Post
Every penny!!!!
Ditto.......and programmable!
TrebGreb is offline   Reply With Quote
Old 01-27-2008, 09:36 AM   #15
RningOnFumes's Avatar
To Project84.
Yes, I have an actron as well as a scangauge, and no the scangauge doesn't "interpret" the readings like the actron does.
Giving a number and an interpretation is useful because you can basically get a gist of what is wrong. I mean yes, I can just look it up, but how about just knowing what is basically wrong? I mean there are certain things like if you get a p0420, if you've run into it before, it's something bad with emissions in the catylytic converter area. So at least you know not to go digging into the intake for cat problem.
RningOnFumes is offline   Reply With Quote
Kenwood KAC-PS401M popimp For Sale 1 07-30-2007 01:53 PM
Kanagawa, Japan is leading the way in fast-charge EV?s GasSavers_roadrunner Electric and Solar powered 5 07-15-2007 05:35 AM
Introduction and Questions minic6 Introduce Yourself - New member Welcome 19 05-14-2007 01:46 PM
TSX / K24a2 Engine: Help! rh77 General Fuel Topics 5 10-07-2006 08:13 PM
Wiki added Matt Timion Fuelly Web Support and Community News 19 03-29-2006 03:27 PM
