Scangauge came in! Questions about DFCO, neutral and throttle control - Fuelly Forums
Old 08-03-2008, 09:54 AM   #1
Well, after a little more experimentation, I've found that I need to stay in gear in order to sustain the 9999 mpg reading...but then after it gets below a certain speed (or rpm), it seems to drop back down to like 50mpg again, as if i were coasting in neutral. Is this the fuel-cut off getting switched off? I put it back into neutral after it drops from 9999...but should i downshift instead? Would the A/C being on or off affect the rpms, thus affecting the time at which the cut-off is switched off?
Also, it seems that SG has a sort of delay in displaying fuel economy in realtime...I think it might be a full 1 second delay. Does this happen to everyone?
Thanks.
FLAteam is offline   Reply With Quote
Landspeeds E-bike Conversion (Mk2) landspeed People Powered 5 06-06-2008 07:37 PM
91 CRX DX 5 Speed Head Gasket Confusion UfoTofU General Maintenance and Repair 2 04-26-2008 10:09 AM
