ScanGauge advice for better MPG... - Page 2 - Fuelly Forums
Old 02-05-2008, 02:05 AM   #11
If you leave it in gear and just coast, you might have fuel cutoff, in which case you go to 9999mpg!!.
by yi5hedr3 above.
I didn't know that's what the 9999mpg meant. On my last tankfull (32.6mpg), I used it a lot coasting as my rig apparently has a very active fuel cutoff. I think I gained an mpg using the technique.
Thanks for the heads up, yi5hedr3.
Tribor
TrebGreb is offline   Reply With Quote
Old 02-05-2008, 11:03 AM   #12
Originally Posted by Snax View Post
For most cars this requires fairly high rpm. So high that it often presents significant compression braking, making it really only useful on steeper grades. Instead of guessing, I just reach for the ignition switch and coast.
Not so on the Yaris. I use fuel cutoff on every coast, and it works very well at most engine speeds until rpms get real low.
yi5hedr3 is offline   Reply With Quote
Old 02-05-2008, 11:08 AM   #13
Originally Posted by Tribor View Post
by yi5hedr3 above.
Tribor
Sure! yeh, I was coasting in neutral before I discovered this, and started getting more MPG right away when I switched to coasting in drive. Any time you're coasting down a hill, especialy towards a stop sign or red light, coast, and you get free mileage!!
Old 02-06-2008, 10:25 PM   #14
GasSavers_jkandell's Avatar
I thought deceleration shut off mode kicked in above 1000 rpm in most modern vehicles. No?
GasSavers_jkandell is offline   Reply With Quote
Old 02-07-2008, 01:06 AM   #15
guest001's Avatar
so what have you noticed in your driving, changes to your driving etc. , since people in this thread, have had your scangauge??
guest001 is offline   Reply With Quote
Old 02-07-2008, 02:23 AM   #16
Snax's Avatar
I think there are allot of cars with higher limits than that. The Imprezas that I had certainly were. Fuzzy memory tells me it was about 2500.
LiberalImage.com
I think, therefore I doubt.
Old 02-07-2008, 05:46 AM   #17
The ScanGaugeII is a nice diversion (ongoing displays of info and adjustments to improve numbers). Without it, it would be way too boring to endure for me.
I've been trying stuff that more experienced hypermilers have written about. Trying EOC--engine off coasting--approaching stop lights and realizing I'm saving more fuel. Coasting--in gear (w stick shift)-- and getting the 9999mpg reading and knowing the fuel flow is off and I'm saving yet more fuel. Looking at TPS--throttle position reading--and knowing that "feather footing" works. It's a lot of fun to manage this stuff to better mpg's. I think it would be great fun with an older Honda hybrid with a stick shift and dash light cues for up and down shifting combined with a ScanGaugeII..
So it's about entertaining yourself, saving $, not getting bored doing it!, and--probably most importantly--not becoming a hazard "out there".
Tribor
url=http://www.gassavers.org/garage/view/1146][/url]
Old 02-07-2008, 06:51 AM   #18
guest001's Avatar
Trebor
wait, so EOC or just coasting, which one gets better mileage?? and feather worked? as in just enough throttle to maintain a speed?
Old 02-07-2008, 04:49 PM   #19
EOC=better mpg......yup
Tribor
Old 02-07-2008, 05:19 PM   #20
guest001's Avatar
I'm actually noticing worst mileage with EOC. I dunno.... I think I'm doing it places where its worth it, pretty long stretches of road, over 30 seconds at least.
is compression starting(bump starting) the key or does that not have anything to do with it??
protium gas optimizer? honda_afford General Fuel Topics 7 09-12-2007 04:47 PM
Official crxMPG news/update/suggestion/idea Thread SVOboy General Discussion (Off-Topic) 47 09-19-2006 11:29 AM
