ScanGauge? - Fuelly Forums
Old 08-05-2006, 04:51 PM   #1
ScanGauge?
My '91 Festiva was built prior to OBD I and OBD II, does this mean I can't use any sort of ScanGauge? Is a vacuum gauge my only tool to use?
"If the engine ain't running it ain't using gas!"
GasSavers_Kraig is offline   Reply With Quote
Old 08-05-2006, 04:53 PM   #2
You could pick up a superMID from Matt, which is what I use on my crx. You'll prolly have inaccurate instantaneous but you ought to be able to dial in the long term fuel trim. I don't really mind it being inaccurate, relative performance is all that really matters.
Old 08-05-2006, 04:54 PM   #3
What year is your CRX?
Old 08-05-2006, 04:56 PM   #4
91, originally pre-OBD (OBD0 as we call it), but now it's OBD1.
Old 08-05-2006, 04:56 PM   #5
What is the significance of "SVOboy"? Straight vegetable oil?
I ask because I own a Comp Prep SVO Mustang...........
Old 08-05-2006, 04:57 PM   #6
Veggie Oil, my main man.
Old 08-05-2006, 05:01 PM   #7
Is your CRX a diesel ? lol
Old 08-05-2006, 05:03 PM   #8
Nah, I just carried the name over from when I was into dubs three years ago.
Old 08-05-2006, 06:18 PM   #9
Matt Timion's Avatar
As SVOBoy mentioned, a SuperMID should work.
I see no reason why it can't be accurately calibrated. I'm going to be sending off for a batch soon. I'll make an annoucement when they are available.
If by chance your have a carburator, I would recommend looking for a Zemco Computer on ebay.
Old 08-06-2006, 10:48 AM   #10
SuperMid
Matt,
I was reading a thread about the SuperMid. It looks like it needs two connections? One to an injector and one to a speed sensor? The injector is no problem for me, but I believe a Festiva speedo uses a cable to drive it and it doesn't have cruise control. So I'm not sure a SuperMid would work for me? Any other alternatives besides converting over to the electronics from an Aspire and then run a ScanGauge (to much work for me)?
Warning: Bad to bump start and skip gears budomove General Fuel Topics 55 06-06-2008 06:40 AM
Mothballs / Napthalene / WD40 SVOboy General Fuel Topics 24 11-12-2007 08:17 PM
No Self serve in NJ zpiloto General Discussion (Off-Topic) 6 06-07-2006 12:21 PM
Atlanta Auto Show GasSavers_DaX General Discussion (Off-Topic) 26 05-07-2006 05:02 PM
Wiki added Matt Timion Fuelly Web Support and Community News 19 03-29-2006 03:27 PM
