ScanGauge? - Page 2 - Fuelly Forums
Old 08-07-2006, 11:30 AM   #11
Kraig: Can you give us a better idea of what the Festiva has. Is it fuel injected or carburated? If it's fuel injected, is it MPFI or something else.
Old 08-07-2006, 11:31 AM   #12
I'm fairly sure it'd be some Fordy/Mazday version of MPFI.
Old 08-07-2006, 11:57 AM   #13
Matt Timion's Avatar
Originally Posted by Kraig
Matt,
I was reading a thread about the SuperMid. It looks like it needs two connections? One to an injector and one to a speed sensor? The injector is no problem for me, but I believe a Festiva speedo uses a cable to drive it and it doesn't have cruise control. So I'm not sure a SuperMid would work for me? Any other alternatives besides converting over to the electronics from an Aspire and then run a ScanGauge (to much work for me)?
Yoshi told me that he found a magnetic alternative for the supermid. It seems like it would work, but it woudl cost a little extra to get it working (Yoshi needs to add an extra sensor to the SuperMID to get it to function properly).
Old 08-07-2006, 12:06 PM   #14
Mid 80's chrysler products had a device that hung on top of the transmission, where the speedometer cable comes out. It was basically an adapter that received the cable and then had a cable replacement to go into the speedometer. The sensor had 2 wires off of it, so that it could be used for cruise control. I wonder if something like that might work on the Festiva?
Old 08-07-2006, 01:19 PM   #15
Mpfi
The Festiva does have MPFI with a vane air meter etc (not speed density). I'm sure it is Mazda derived as is the rest of the drivetrain. The body and final assembly was by KIA (made in Korea sticker on 'em). The motor is a 1.3 liter four banger with 63 hp and like 58 ft lbs of torque.
"If the engine ain't running it ain't using gas!"
GasSavers_Kraig is offline   Reply With Quote
Old 08-07-2006, 04:12 PM   #16
Hello from Japan,
Yes. I got some sample speed sensors as a picture below.
It has a lead switch and produces four ON-OFF signals per revolution which is the same number of digital SPD signal required for the SuperMID M-1.
We need some circuit to clean up noises and chattering of the lead switch.
Anyway, it should work on the Festiva.
Yoshi
GasSavers_Yoshi is offline   Reply With Quote
Warning: Bad to bump start and skip gears budomove General Fuel Topics 55 06-06-2008 06:40 AM
Mothballs / Napthalene / WD40 SVOboy General Fuel Topics 24 11-12-2007 08:17 PM
No Self serve in NJ zpiloto General Discussion (Off-Topic) 6 06-07-2006 12:21 PM
Atlanta Auto Show GasSavers_DaX General Discussion (Off-Topic) 26 05-07-2006 05:02 PM
Wiki added Matt Timion Fuelly Web Support and Community News 19 03-29-2006 03:27 PM
