ScanGauge 2 Idle RPM Question - Fuelly Forums
Old 09-27-2008, 02:13 PM   #1
Send a message via AIM to jeep45238
When I've got the key to on, but the engine not running, my RPM shows 61. I know it's pretty trivial, but it's annoying.
Does anybody know about any setting to change this? I haven't been able to find one in the manual. The gauge is about a month old.
Democracy is two wolves and a sheep deciding what to have for dinner. Liberty is a well armed sheep contesting that decision.
jeep45238 is offline   Reply With Quote
Old 09-27-2008, 02:37 PM   #2
Did you setup the engine displacement in the settings?
Old 09-27-2008, 02:51 PM   #3
Yup. Engine size, fuel tank were set. I don't know the fuel cut off so I left it as is, and the tire size is 1 mph off at 65 mph (not enough for me to worry about).
The engine RPM of 61 with the engine off is aggravating at times though.
Old 09-27-2008, 03:03 PM   #4
The cutoff value is only to help the SG detect DFCO. In most cases it is fine at the default. If you do change it, it should be your idle TPS reading +4.
Mine annoys me too. It says I'm using .2 gal/hr while the engine is off.
Old 09-28-2008, 10:44 AM   #5
No wonder the Beast doesn't get good mileage. Even if you drive it 4 hours a day that leaves 20 hours at .2 gallons per hour, 4 gallons shot to hell and didn't go anywhere.
Hipermiler
#47 on my way to #1
Old 09-28-2008, 10:59 AM   #6
LOL, I am hitting the EPA highway rating driving in stop & go city traffic. I think the .2GPH is due to the SG guessing the fuel rate, instead of being able to read it directly from the engine computer. I'm not getting 12 and 13 MPG anymore. That's over a 30% increase so far.
Old 09-29-2008, 07:24 AM   #7
That's a good improvement, but just think of the mileage you'd be getting if you weren't using .2 gallons per hour with the engine off.
Hipermiler
#47 on my way to #1
Old 09-29-2008, 07:59 AM   #8
If that was truly the case I would not have been able to go 18 days between fillups on my last tank. Not driving it at all and using .2 GPH I should have used 86.4 gallons of fuel in 18 days. I drove 293 miles and used 20.9 gallons of fuel. I think when not running its just showing its internal "fudge factor" for interpreting the OBD data.
Old 09-29-2008, 10:53 AM   #9
I'll have to check and see what mine reads with engine off. I use it in the '97 Escort which I seldom drive so I really don't know.
Hipermiler
#47 on my way to #1
Am I calculating this right? stumeston General Fuel Topics 8 12-15-2007 07:56 AM
Timing chain and FE bowtieguy Experiments, Modifications and DIY 22 11-11-2007 08:48 AM
New 91 CRX DX 5 speed from Arizona UfoTofU General Discussion (Off-Topic) 30 10-09-2007 06:12 PM
cool little car boofighter General Fuel Topics 10 06-03-2007 06:55 AM
Ethanol-gas mix is a problem for Franklin ketel0ne Automotive News, Articles and Products 8 08-26-2006 08:36 AM
