Proper RPM - Page 2 - Fuelly Forums
Old 02-01-2010, 09:32 AM   #11
If I go a long time without driving, I'll probably spend that time sitting.
Old 02-02-2010, 01:05 PM   #12
Banned
yea but u dont live in the city where u can walk to get lunch
Old 02-03-2010, 10:04 PM   #13
Member
Geonerd's Avatar
Geonerd, can you elaborate on what data to collect from the ScanGauge? Just instant MPG, or something more?
I haven't thought it through completely, but something like this has been bouncing around in my head for a while...
Find several long, even hills (poor man's dyno) or various slope (increasing load). Drive up them in different gears/RPM, at different speeds, logging instantaneous fuel consumption and throttle position. I don't even have a SG (no place to plug it in!), but I think they can record T.P., as well as the raw fuel consumption rate, right?
If instant consumption values aren't available, MPG would work as well, so long as you factor out the speed, and wind up with gal/hr, ml/min, etc.
(Is there a SG version that can log several minutes' worth of data? That would kick butt!)
Weigh car. Survey hills. Calculate how much power is required to lift the car up the incline at any given speed. Perform coast-down tests (on level ground!) to determine the power required to overcome rolling resistance and aero at any given speed. Add the two to get (theoretically!) the HP/KW needed/produced to maintain speed up the given hill, at the given speed, and divide into recorded fuel consumption. If all has gone per plan, you now have a number representing power produced per fuel consumption rate. "To make X HP/KW, the engine requires N gallon/grams/liters per minute/hour."
Whatever the units, plotting the resultant values on a grid, located at the appropriate TP and RPM intersection, should make a crude BSFC map.
OK, what did I miss?! (I musta missed something! )
Moo
Geonerd is offline   Reply With Quote
Old 02-04-2010, 06:27 AM   #14
You probably did miss something, but it looks good to me.
Old 02-04-2010, 08:55 AM   #15
Member
Geonerd's Avatar
LOL, thanks for the resounding vote of confidence!
Old 02-04-2010, 11:38 AM   #16
FrugalFloyd's Avatar
Scangauges don't offer any data logging capability, so that shoots the whole concept of using one to generate BSFC graphs.
Old 02-04-2010, 04:38 PM   #17
Never the less. They still sound like they could give you a whole lot of good gas saving information
Going GTO once I finally get a job. Stayin pontiac all the way.
NotYourDay is offline   Reply With Quote
Old 02-04-2010, 04:59 PM   #18
You would have to log the data yourself. The ScanGauge is great at displaying the data, and can average/sum some of the data.
Dissolve waste polystyrene (foam cups/plates) in biodiesel for more power theholycow Automotive News, Articles and Products 8 05-07-2009 05:32 AM
drivetrain resistance bagpipe goatee General Fuel Topics 9 09-14-2008 10:04 PM
DashDyno? Anyone heard of it yet? BumblingB General Fuel Topics 10 02-20-2008 09:09 AM
How does Automatic Tranny choose? GeekGuyAndy Transmissions and Running Gear 5 08-13-2007 05:05 AM
GasSavers.org Stickers Matt Timion Fuelly Web Support and Community News 7 10-12-2006 04:48 PM
