Driving slightly different today, as I took Mrs Jocko to work. Noticed that as soon as Closed Loop is active, so too is DFCO, but only at slightly higher rpm. When in Closed loop at 1500 rpm with a warm engine DFCO is operative, however with a cold engine it drops out below 2000 rpm.
Today I was revving a bit freer and changing up at a slightly higher speed, which meant that in turn I was coasting in gear from a slightly higher speed. Fuel figure for the morning 4 miles was a bit better too.
Honda Jazz has a very small throttle movement. While monitoring the Throttle Position Sensor (which reads from 12 with foot off to 85 at full throttle) I observed that it reaches full throttle (85) long before the pedal reaches the metal. I have always found the throttle very finicky and this explains why. The "drive by wire" throttle has a very small range. I think it would benefit from being driven without shoes.
