Long EOC no brakes at the bottom - Page 4 - Fuelly Forums
Old 06-19-2006, 05:05 AM   #31
GasSavers_Jack's Avatar
You should leave the key in the run position if you are going to coast with the engine off. The reason for this is that, when you are in the accessory position in most cars, your odometer isn't registering mileage. This would kind of defeat the whole purpose of Engine Off Coasting which is to rack up mileage without the engine running.
My odometer is mechanical so it still registers even with the car off. I also started the "turn the engine trick" while the car was off to rebuild vacuum. I was trying to figure out how bad that is for the engine. Any input on that?
See my car here:
Old 06-19-2006, 08:43 AM   #32
Moderator
GasSavers_DaX's Avatar
As long as your engine uses a mechanical oil pump (I think most do), you should be fine.
Old 06-19-2006, 08:48 AM   #33
Thanks. I was hoping that was the answer.
See my car here:
Fuelly App Chrisbad Fuelly Web Support and Community News 3 11-13-2013 09:03 PM
Adding the 2013 Ford Fusion Energi? JDsEnergi Fuelly Web Support and Community News 1 06-27-2013 12:49 PM
Feature request: input "validation" override Volta Fuelly Web Support and Community News 8 08-20-2008 12:20 AM
Fleet/Brand metrics? handruin Fuelly Web Support and Community News 1 08-19-2008 01:50 PM
Best fuel economy for the buck pb General Fuel Topics 10 08-15-2008 11:04 AM
