inventor of the ScanGauge - Page 3 - Fuelly Forums
Old 02-19-2007, 09:29 AM   #21
Semi-retired OPEC Buster
BeeUU's Avatar
Thanks!!!
B W
BeeUU is offline   Reply With Quote
Old 02-19-2007, 10:27 AM   #22
Does the ECU measure engine oil pressure???
Great that we may have Average MPG on the 4 number display!
My last fiillup was within .1 gallons of the SG reading with a 10.725 gallon fillup using the correction factor.
Old 02-19-2007, 11:33 AM   #23
cfg83's Avatar
Hello -
Why does the SG report 0.1 GPH with the engine off in neutral coast (i.e. SG sees X MPH + 0 RPM)? It should be reporting 0.0 GPH @ 0 RPM under any and all circumstances.
A compromise for divide by zero errors would would be to have a super small GPH, i.e. 0.001 GPH. For the purpose of the display, this would appear to be 0.0 GPH.
Old 02-19-2007, 11:44 AM   #24
CarloSW2 - you'll have to send that question directly to the SG people. I haven't checked to see if mine does that (I do know it shows 9999 mpg on the instant gauge in those circumstances.)
Old 02-21-2007, 04:46 PM   #25
For those following this thread, the interview is now up at metrompg.com:
http://www.metrompg.com/posts/scangauge-interview.htm
There isn't a lot of new juicy technical info that people who follow the news & rumours about the SG don't already know. Maybe a couple of things:
- how a troublesome Canadian made Ford F-150 led to the development of the SG
- the intention to add user-definable "gauges" to the SG2 for vehicles which offer more info through ODBII than the standard pre-defined set of gauges (e.g. your vehicle may have multiple temp sensors, gear indicators, etc.)
- the fact that the current unit is currenly using less than 1/2 of its processing capability, leaving lots of room for future SG2 improvements via downloadable upgrades.
- Ron's assertion that the SG2 will have a "long shelf life" - meaning the focus is on software development, not changes to the hardware.
Old 02-21-2007, 06:56 PM   #26
Yesterday I changed to Liters and found that my .1ghp idle fuel rate was 0.5LPH and sometimes 0.6LPH so there is a little bit more resolution using Liters than gallons.
Mothballs / Napthalene / WD40 SVOboy General Fuel Topics 24 11-12-2007 09:17 PM
Anyone have experience making their own solar panels? MetroMPG Electric and Solar powered 17 08-29-2007 06:43 PM
Hovercraft 88HF General Fuel Topics 2 06-21-2007 11:41 PM
Belated Intro GasSavers_brick Introduce Yourself - New member Welcome 4 12-22-2006 07:48 AM
Atlanta Auto Show GasSavers_DaX General Discussion (Off-Topic) 26 05-07-2006 06:02 PM
