Idling versus Shutting Off the Car - Page 4 - Fuelly Forums
Old 03-08-2006, 12:04 PM   #31
philmcneal's Avatar
Quote:i've already got a
i've already got a simple experiment in mind: compare mpg from idling/neutral coasting to engine off coasting over the same city route.
Looking forward to it.
Old 03-10-2006, 11:44 AM   #32
went out to do some errands
went out to do some errands this afternoon (first time i've used the car since... sunday??)
so, i incorporated the comparison test between engine on VS engine off coasting into my drive.
i'll post the details later. but the figures are so good, i wanted to get them up here for your enjoyment. the fact is, i'm having a hard time believing they're accurate.
first, i can report that the kill switch works as hoped in practice: it kills the engine; doesn't put the scangauge to sleep; all the instruments (speedo/odo) continue working; and the engine can be key-/or bump-started with no difficulty afterwards.
i will have to get used to the switch though; i left it "off" by mistake a couple of times, causing me to miss one bump-start opportunity and forcing a key-start. krousdb - i can see the utility of an "interrupt" switch as you had set up. but i'll learn to use this properly since it can also serve as a simple security device.
(btw - bump start is inappropriate terminology for the technique; there's no "bump" when done correctly. we need to come up with a better term.)
anyway, the figures:
10 km loop; 100% city driving (stops every 3-5 blocks); several small hills; 3 longer hills; approx 17.5 to 18 minutes to complete each loop
light drizzle; damp/wet roads
60.3 mpg (US) - "engine OFF while coasting" loop
53.4 mpg (US) - "engine idling while coasting" loop
car was warmed up prior to test.
also, the warm weather has blown in from PA, apparently:
Conditions at SUPN6 as of (2:00 pm EST) 1900 GMT on 03/10/2006:
Wind Direction (WDIR): SW ( 220 deg true )
Wind Speed (WSPD): 22 kts
Wind Gust (GST): 25 kts
Atmospheric Pressure (PRES): 29.44 in
Air Temperature (ATMP): 45.7 °F
Old 03-10-2006, 01:11 PM   #33
krousdb's Avatar
Re: went out to do some errands
Sounds about right. I would have guessed 10%. As for renaming the bump start, nothing catchy comes to mind. I was thinking momentum start or clutch start, but those sound awkward.
Glad to be of service. Would you like me to send you some more? :-)
Old 03-10-2006, 01:46 PM   #34
yes please, keep it coming. (i'm sure you're tired of me sending weather in your direction.)
re: bump start... how about "stealth start"?
Old 03-10-2006, 02:32 PM   #35
Matt Timion's Avatar
How about "running start?" LOL
Old 03-10-2006, 03:27 PM   #36
yeah running start could
yeah running start could work too. except it's not really running when i start it... and when it is, it makes that terrible sound
i just did another short city trip. both legs were cold starts (drove about 4 km, parked for 40 minutes, drove back again.)
used the on/off switch a bunch of times, and managed 51.5 mpg round trip. on a cold motor. in city driving. that rocks!
why did i wait so long to try this? (if it's for real.... will have to wait a couple of weeks to see what this tank says at fill-up time)
currently the switch is duct taped to my shifter, dangling wires everywhere. flick of the thumb does the job. very ergonomic. ugly as hell too. i may have to fix that up.
i'll write up a proper description of the day's events and post a new experiment thread.
Old 03-13-2006, 06:30 PM   #37
Re: yeah running start could
experiment thread posted:
http://www.gassavers.org/forum_topic/coasting_experiment_engine_on_vs_engine_off_on_a_f ixed_route.html
Add Vehicle Nicknames to Facebook Posts meissen Fuelly Web Support and Community News 2 08-13-2012 09:16 AM
Fuelly badge not updating for about 2 - 3 weeks Need Fuelly Web Support and Community News 18 07-01-2012 03:01 PM
VW Jetta fast riser coolbreeze General Fuel Topics 5 07-22-2009 12:25 AM
Condensator orevgym General Fuel Topics 0 07-23-2006 11:25 AM
