Hypermiling questions... - Fuelly Forums
Old 05-29-2008, 12:16 PM   #1
Send a message via AIM to Dave1215
Alright, so I do EOC some of the time, but most of the time I leave it in neutral, but I remember reading that leaving it in gear causes a fuel cutoff. So which technique is better, leaving it in neutral with the engine on, or putting it in 5th in my VX tranny when i'm coasting down a hill.
Next question, does P&G work with the in-gear solution effectively?
Thanks,
Dave
Best Tank: 54.43 mpg
Dave1215 is offline   Reply With Quote
Old 05-29-2008, 12:32 PM   #2
Neutral is generally better. DFCO is great when you need to slow down anyway, but if you're trying to P&G then it costs more energy by slowing down the vehicle than it saves by cutting off fuel.
Old 05-30-2008, 07:59 AM   #3
Agreed, even 5th gear slows you down more than coasting in neutral, thou it can come in handy should you need this effect such as on certain down hills where you might otherwise severely exceed the speed limit.
Mitsubishi L200 S T O R M V6 consumption increase 2drive General Fuel Topics 3 06-03-2011 03:30 AM
thinking about an underbody fairing lunarhighway Aerodynamics 6 10-27-2007 06:17 AM
VX tailgate and other parts 1993CivicVX For Sale 0 09-24-2007 07:11 PM
aluminum vs. steel Erdrick General Fuel Topics 18 05-25-2007 06:04 AM
LA Auto Show pix ... cfg83 General Discussion (Off-Topic) 3 12-04-2006 03:21 PM
