Humble request about ScanGauge 2 - Fuelly Forums
Old 01-07-2008, 04:54 AM   #1
RningOnFumes's Avatar
Good Morning.
I've done a couple of searches on the subject of the scan gauge 2 here in the forums. Among the threads that popped up, none of them were thorough in it's use in direct application to efficient mpgs. Most of the threads answer the poster's immediate questions and did not elaboratE.
If I over looked a thread, please point me in the right direction? I guess I'm looking for a post which will tell me the how to's of all the gauges from the scangauge or even the supermid. What may be the best guages to monitor? If starting out (ie rookie hypermiler), which gauge to pay attention to? What to do exactly with each information...*ie how to drive according to the read out... etc...etc...etc.. A basic how to along the lines of the post that can be found on how to P & G..
And if there is no post to be found, if an experienced member would kindly do a write up for those of us who are rookies at hypermiling and the scanguage? Basically applying the hypermiling methods using scangauge information?
Again, thank you.
Dave
RningOnFumes is offline   Reply With Quote
Old 01-07-2008, 10:22 AM   #2
Good questions. I've wondered about this myself. I've found LOaD and Average Fuel Economy to be my most watched gauges. I shoot for 85-90 LOD and use AFE for feedback. It will depend on your vehicle though.
GasSavers_landon is offline   Reply With Quote
Old 01-07-2008, 04:22 PM   #3
I use the TPS (throttle position sensor) setting and the instantaneous MPG readouts quite a bit to modulate my acceleration. Try to keep the TPS number low, meaning you're using the least amount of throttle. The instantaneous readout is good for monitoring your MPG on the go and finding your most efficient cruising speed - for me it's 46mph @ 53mpg in my Focus. Other things that can help are the FWT (degrees water temperature) - this lets you know when the car is warmed up, information that fuel injected cars use to run "closed loop", their most efficient setting.
'00 Echo - DD
'11 Kia Rio - Wife's DD
Old 01-07-2008, 06:02 PM   #4
basjoos's Avatar
On the SuperMID, I'm mainly monitoring the injector pulsewidths, the 5km average Km/L, and the total average Km/L.
aerocivic.com
Saturn TDI for S-Series cfg83 Diesels 14 10-02-2007 02:24 PM
Anyone have experience making their own solar panels? MetroMPG Electric and Solar powered 17 08-29-2007 06:43 PM
the new guy ccoelnslash Introduce Yourself - New member Welcome 1 07-10-2007 10:12 AM
hi SuperRobot46000 Introduce Yourself - New member Welcome 6 07-15-2006 07:44 PM
Atlanta Auto Show GasSavers_DaX General Discussion (Off-Topic) 26 05-07-2006 06:02 PM
