How do I improve my hypermiling? - Page 2 - Fuelly Forums
Old 06-11-2009, 09:51 AM   #11
100% grille blocking on my GMC and VW:
The VW's upper grille blocking was done behind the grille.
Old 06-11-2009, 11:46 AM   #12
How's that 100% block on your truck effecting the a/c now that summer is here? I was not pleased when I only had one 4" hole in mine, so I cut a second one in there.
Old 06-11-2009, 11:47 AM   #13
I took it off in the winter when my transmission was getting too hot. I don't drive the truck much in the summer so I haven't bothered re-doing the grille block.
Old 06-11-2009, 02:33 PM   #14
Blocking off the grille from behind sounds interesting. My grille is rather small but it is deep. You can see an example here.
http://autos.yahoo.com/2009_hyundai_...hWPeb8F;_ylv=3
The '09 grille is no different than '07 grille. How much loss of benefit is there between completely blocking the grille from the front vs. the rear vs. not at all? Is there still enough air circulation from under the car to keep the engine cool?
I like this in general because it does not seem terribly complicated.
-- Boris
kristiancyclist is offline   Reply With Quote
Old 06-11-2009, 02:38 PM   #15
Oh, and I forgot to say that I do not have a ScanGauge. I would like one but at $160 from Amazon, that seems a bit steep.
-- Boris
Old 06-11-2009, 02:58 PM   #16
Grille blocking differs from one car to the next. On both my VW and my GMC, I could block off 100% of the radiator or the grille and the engine temperature was not affected (but the GMC's automatic transmission fluid temperature went way up).
User maximilian talked about grille blocking with his Accent here:
http://www.gassavers.org/showthread.php?t=10437
You might want to post in his thread asking if he ever did it and how it affected his temperature. He did try taping off the entire upper grille and did not experience any temperature increase, but the lower grille is probably where most of your cooling and aerodynamic drag comes from.
As for the ScanGauge, if you've got some kind of fuel rate or fuel economy display then it might not pay for itself. It's a great tool and a great toy for anyone interested in cars. Some of its other functions can be had less expensively (a code scanner/clearer and a hacky DIY fuel rate meter can be had for investments of $40/each). If you don't have any realtime fuel economy or fuel rate display then it will easily pay for itself by teaching you about your car and your roads.
Mitsubishi L200 S T O R M V6 consumption increase 2drive General Fuel Topics 3 06-03-2011 03:30 AM
shopping for o2 sensor 1993CivicVX General Maintenance and Repair 2 10-27-2008 02:04 PM
Check engine light code 48 92VXHatchguy General Fuel Topics 6 05-20-2008 03:49 PM
Top cylinder lubricators? Greybrick General Fuel Topics 3 02-20-2008 10:37 AM
How does Automatic Tranny choose? GeekGuyAndy Transmissions and Running Gear 5 08-13-2007 05:05 AM
