Higher gear not always good for mpg?! - Page 2 - Fuelly Forums
Old 05-16-2006, 08:43 PM   #11
I'm gonna just hook up a
I'm gonna just hook up a vaccum gauge.
budomove is offline   Reply With Quote
Old 05-16-2006, 10:19 PM   #12
what gear
I find the mpg almost the same in 4th and 5th if going up a steep hill and for a long hill recommend the lower gear with a little more rpm just for better timing advance and oil cooling the piston bottoms with more spray and better water pump speed. At light throttle higher gears are better over 1000 rpm which in 5th is about 20mph although 4th gives the same mpg but 3rd lowers mpg at 20mph. Long putting reduces lubrication in the engine so once in a while higher rpms will help mpg even throwing a rev with the clutch in helps.
Old 05-16-2006, 11:40 PM   #13
philmcneal's Avatar
5th gear owns all.
5th gear owns all.
Less friction less bull****, even climbing mild hills in 5th is awesome because for my car the speed bleeds MUCH slower than opposed to trying to climb 1500 rpms in 4th as opposed to 1200 rpms in 5th which suprisingly is the real winnar!
4th sucks.
Look at it this way, in city even at speeds as low as 45 km/h in 5th my engine load only goes as max as 30 and that's max. ON the highway at 100 km/h with rpms at 2800 my engine load is as high as 50 and that's constant!
Areodynamic is a *****.
Old 05-17-2006, 02:28 AM   #14
krousdb's Avatar
Re: I'll discredit it for
Originally Posted by SVOboy
I'll discredit it for you...
Dan has tested and he tells me that no matter what the slower you go in 5th the better your gas mileage, even if you're madly lugging.
Yes, all true. I climb mild grades in 5th gear at 1200RPM, 55MPG, Fifth gear is always the best for me at any speed down to 20 MPH. But for speeds over 45, 6th gear is best. Too bad I dont have one.
Suggestion: Other ideas for comparing cars' data jjmatt33 Fuelly Web Support and Community News 6 08-08-2008 02:38 PM
1988 Honda Acty Attack all wheel drive iburnh2o For Sale 12 06-01-2008 05:30 PM
Happy Holidays everyone! Matt Timion General Discussion (Off-Topic) 10 12-29-2005 12:07 PM
vegpowered systems GasSavers_Diemaster Vegetable Oil and BioDiesel 2 09-08-2005 05:53 PM
