Help, Codfishing - Page 2 - Fuelly Forums
Old 06-22-2006, 02:52 PM   #11
I need to read this when I'm not spacing out, I'd love a kill switch...
Old 06-22-2006, 02:59 PM   #12
95metro's Avatar
You need one for the MID, don't you? You must lose the VSS signal otherwise...
95metro is offline   Reply With Quote
Old 06-22-2006, 03:22 PM   #13
I have the MID hooked up to constant power, anyway, I just wanna have a kill switch anyway.
Old 06-22-2006, 03:28 PM   #14
95metro's Avatar
Yeah but doesn't the MID use the VSS signal from the ECU? When you shut off your engine doesn't the MID lose contact with the ECU for a second or two until you key back on? Or does your ECU have constant power as well?
Old 06-22-2006, 03:31 PM   #15
My MID is wired directly to the VSS. Since I put the vss in there I got to do it however I pleased, so that's how it goes. Anyway, I think the ecu gets power with the engine off, it just semi-shuts down.
Old 06-22-2006, 03:56 PM   #16
95metro's Avatar
Ah, I see. You bypassed the VSS to ECU connection. Very nice.
Old 06-22-2006, 04:00 PM   #17
No, that's there also, if not it throws a code if I use the brakes while in gear. Random, I know, but it exists.
Old 06-22-2006, 04:01 PM   #18
95metro's Avatar
But you put the MID in the middle of the loop, not on the ECU end, right?
Old 06-22-2006, 04:04 PM   #19
I think I have 1 branch going to the mid, one to the cluster, and one to the ecu. The stock teg cluster had it set up with branches so I just added a branch.
Old 06-22-2006, 11:12 PM   #20
Bunger's Avatar
Originally Posted by Gary Palmer
My effort was to attempt to be able to turn off the engine, without messing with my ignition key, since it is wayyy to easy to turn the key off, lock up the steering and all of that business.
Remove the steering wheel lock. I did this years ago for Honda-Challenge rules and I don't miss it at ALL. There have been plenty of times that I didn't have my keys on my, but wanted to push the car somewhere. =)
Anger is a gift!
- Zack de la Rocha
Misleading milage histograms DrewE Fuelly Web Support and Community News 3 06-26-2012 12:53 AM
Metric Data Entry Added pb Fuelly Web Support and Community News 19 08-15-2008 07:01 AM
Optional data to add EmptyH Fuelly Web Support and Community News 1 08-10-2008 03:05 PM
A tidbit about IAT temps and resistance SVOboy General Fuel Topics 9 02-05-2006 01:06 PM
